K5 electrical question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K588, Feb 1, 2006.
  1. K588
    K588 1/2 ton status Premium Member
    Feb 19, 2005
    332
    19
    Westminster,Maryland
    I have an 88 K5 and electrical trouble shooting is not my strongest skill. The problem I have is the parking lights stay on all the time and I have no dash/gauge lights. I dont know if the 2 problems are related some how. I have replaced the headlight switch and checked all the fuses. it has been like this since i have owned it. Any help or suggestions would be appreciated.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    When you say "all the time" do you mean all the time? running,not running, keys in, keys out, they dont blink or change no matter what?
  3. K588
    Feb 19, 2005
    332
    19
    Sorry, parking lights- by all the time I meant when the truck is running. They turn off when you turn the key off. Dash lights never work.
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Sounds like the switch on the dash. I had one short out internally causing the lights to stay on like you describe. They are not hard to remove if you know how to remove the knob. You have to pull it out, then press in a little button on the switch and the knob will pull the rest of the way out. Just use a multimeter to check the switch contacts. In my case I just used the switch out of a truck I was scrapping.
  5. dyeager535
    26,975
    Pull the headlight switch connector off and see if the problem goes away, first thing.
    Would be odd that the new one and old failed the same way. I'd suspect someone has hacked the wiring up somewhere.
  6. wkbrdrob
    wkbrdrob Registered Member
    Feb 7, 2006
    63
    Salem, OR
    When I bought my truck, I had all kinds of screwy electrical problems. M dash when on and off by themselves and the light bulbs were just loose in the dash. Some dumb ass put the wrong tail light into the truck and screwed up all of my brake lights, turn signals, etc. You'd be surprised how easy it could be. Remember, it's always a ground problem!
  7. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    If the lights don't go out when you unplug the headlight switch, try disconnecting the radio. I have seen some people wire up the radio's wiring harness to the wrong fuse or wire, causing the radio to turn on the lights and/or short out the dash lights. Good luck...
