K5 Gas lines from filler neck to tank?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Klef72K5, Aug 5, 2005.
  1. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    Has anyone tried to buy the two gas lines that go from the filler neck to the tank on a K5? I keep getting told they don't exist, someone has to have these dang things!
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I had the same prob with my '73. It needs a 1 3/8" line, and all I could find was 1 1/4" or 1 1/2". I went to a Chevy dealer and he said he could get it for like $40. I had him write down the p/n and got it from GM PartsDirect for only $13 or so.
  3. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I went to a local hose company and they had it available cut to fit. I initially bought one from a parts vendor and it was the wrong size.
  4. Klef72K5
    Apr 8, 2001
    249
    were these premolded or have wire in them to keep from kinking up?
  5. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    I priced a Stainless set over at http://www.classicheartbeat.com Wes I think said the were around $80 for them if you get the origanal steel probly half the price. check threw his on line catalog they may be in it.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Lmc?
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    LMC has them
  8. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I believe there was a wire running in the larger of the two hoses that I had to cut. It was pretty stiff.
  9. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    try napa. that's where i gotmine. also try truck/farm equipment shops and such. they always have stuff like that laying around.
    ARQ.
  10. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    Anyone changed out the metal section of filler tube that is hidden in the body between the neck and the rubber hose?Mine is leaking and I'm gonna have to do something about it soon.Thanks...Allen
  11. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I got my 1 and 3/8 at a local parts store. I checked 5 places and this one had just enough to do the jimmy. I was told you can also ask for hydraulic hose. If the hose stands up to hydro fluid gas won't be a problem.
    If nothing else LMC as stated earlier.
    My metal filler line was repaired by someone before I got it. I replaced it when I redidi my gas cap and used stuff from a tahoe but then I relocated the filler and used an inset bling bling door $$$$$$$$$$$
  12. roechambeau
    roechambeau Registered Member
    Nov 18, 2004
    22
    peoria, illinois
    i bought mine from LMC. it worked fine, but after two years i have cracking and dryrot. not saying anything bad about LMC or anything. just wondering if there is a better more durable design? the hose was a piece of standard wire reinforced hose(USCG approved, so something tells me it might also be available from a marine shop) that any hydraulic or commercial hose shop would carry.
