K5 Heat-A/C
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chiefheaphy, Mar 13, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    :D Anyone know how to keep the heat but remove all the A/C luggage?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah remove A/C system replace with heat system only :D
    Or just remove the compressor and dryer and remove the radiator, you will still have the big box in the firewall but you will not lose any energy from the A/C
  3. Kiqman
    Kiqman 1/2 ton status
    Dec 14, 2004
    102
    Portland Oregon
    Most any part store sells a part that elliminates the A/C pulley from the serpentine belt system so you don't lose any power. Then you can pull the A/C parts out to save weight if you really want to. (spelling?)
  4. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,238
    284
    San Jose, California
    I'm doing the opposite in mine. (removing the heat only and adding the AC). If it's anything like the earlier k5's just grab a heat only box and fan from a wrecking yard and swap it in. But for just removing the AC, it seems easier to just disable the compressor.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Why remove the heat?:confused::confused::confused:
  6. bp71k5
    Mar 31, 2006
    6,238
    284
    Sorry, that's not what I meant. I should have said: Removing the Heat-only stuff and replacing it with Heat+AC stuff.
  7. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    what year is your blazer that you are pulling the A/C stuff out of?
  8. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    heat only
    88'
    I yanked the A/C the other day. I'm thinkin for heat only I just attach the heater core hoses to the manifold or manifold and radiator. Get a new blower motor and cover the A/C hole on the right with sheet metal. As for in cab, I would just keep the same controls. Good thing its warmin up on the East coast (snow is melting).
  9. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Don't ditch the AC compressor or at least the brackets. If you are dumping the AC, think about converting to on-board air.
