K5 Is Gutless
Discussion in 'The Garage' started by jacob_coulter, Jun 28, 2005.
  1. jacob_coulter
    jacob_coulter Registered Member
    Jun 28, 2005
    12
    USA
    My friend and I are working on a '78 k5 blazer, and it's in great shape, with a rebuilt 350, and the 10,000 pound GCW "Trailering Special" option. The problem is, the car is an absolute dog. The car has trouble getting to 60 mph, and exceeding that speed is nearly impossible. The tires are 33 x 12.50 15 LT. The car idles and starts great, it just doesn't have much grunt.. The engine has a stock GM dual plane manifold (No EGR) with a stock quadrajet with a dual exhaust, no Cats. According to the build plate, the car has 3.73 gears.
    I wanted to do some light performance mods, and wanted to see what you guys thought of this:
    Hooker k5 headers
    Edelbrock performer RPM intake manifold
    1" Carb Spacer
    Advance curve kit
    I also wanted to step up the stock quadrajet with some richer metering rods/jets. Should I go up, say 2 sizes? Is there a size you guys would recommend?
    Any help would be greatly appreciated. I love this vehicle, but it's almost hard to drive in normal traffic. I'm not looking for a hot rod, just some decent power.
    Thanks for your time,
    Jacob
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    the ign. recurve kit might help. have you checked the timing or done a basic tuneup? if the timing isnt advancing properly you'll be losing quite a bit of power. i wouldnt go switching jets unless you know the fuel mixture is off.
    make sure the accelerater pump and secondaries are functioning properly. i've had both of these problems before and makes a world of difference when they're fixed. Qjet's are kinda tricky, might be a good idea to let a pro take a look at it.
    new manifold would help some too, but i'd get a regular performer manifold, not the RPM. you want torque, not high rpm horsepower. you should be able to make decent power(torque) with the stock manifolds, but headers woundnt hurt.
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    From my experience, the 1" spacer won't do anything for you, and the RPM series intakes are for higher-rpm (4500rpms+) performance. The intake is a good idea but look for something milder than the RPM series - like the regular Performer. headers are a good idea too.
    How's the condition of the ignition system? Maybe do a tuneup?
  4. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Like MTMike said, don't mess with the carb spacer. It just changes the power band characteristics, doesn't add power.
    You need to do the metering rod changes in stages, not one big jump.
    If you after acceleration off the line, get a higher stall converter.
    Is the tranny kicking down properly?
    Before spending a lot of money, you may want to do a compressoin test or have one done if you don't have the tools. Maybe you need a rebuild.
  5. dyeager535
    26,979
    "Gutless" is a relative term. :) If you can't get up to 60, then yes, you likely have a real (or multiple) problems.
    If it is truly lacking power it should have, then look towards things like the ignition system, rear axle, exhaust, etc.
    A truck that old cannot be relied upon to currently have the axle ratio that it was built with.
    A stock truck has no problem running up to 60MPH, need to figure out what is wrong with yours instead of putting $$ into things that WILL help to free up some power, but won't do anything to solve the existing problem.
  6. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    try doin a tune up, plugs, wires, cap and rotor.....
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Im with everyone else on this one. The 350 in your blazer should turn those tires with no problem. Something else is the problem here. First, put a timing light on it and check the timing. Then check the cap, rotor, plugs, wires, etc. Then check the fuel filter, fuel pump, and carb to make sure they are all in correct working order. Then check the compression. Then check the gear ratio in the rearend. Like someone said before, in a truck that is that old, you can never tell what gears are in it until you check. Are you sure its a 350? The 350 shares the same block with the 305 and its sometimes hard to tell the difference. Im asking because I know for a fact that even a stock 350 can have plenty enough power. My brother has a 79, and when he first got it, the engine was worn out, it had 35's, and 3.08 gears and the truck had no problem moving to 60. I have an 87 with 37's and 4.56 gears, and it has plenty of power. Something is definitely wrong with your blazer. I suggest checking everything that you can possibly think of to find out what it is. Buying headers, an intake, and putting some new heads on are great ways to give you more power. But you need to get it producing its power at 100% before you try to cover it up with these mods. Just my $.02.
    -Harrison
  8. Cliffy472
    Cliffy472 Newbie
    Jun 27, 2005
    3
    Brighton, CO
    Sorry Spam Removed....I know better...:(
  9. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    blocked exhaust??
    Checked the cataliytic converter to see if its clogged??--some Y pipes have been known to collapse internally where they are double walled,choking the exhaust flow...this is a big cause of power loss,along with all the usual tune up and carb possibilities..you need to have plenty of air going IN too--hows the air filter?? :crazy:
  10. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Sounds like something is amiss in the motor. Even with a fouled cylinder, I was still able to get moving and moving along pretty good. Gas mileage sucked and had the wonderful aroma of fuel when I stopped, ride spitted and sputtered but once she was above 70 or so, it smoothed out. If you are relying on the speedo, make sure it is not wrong as you have bigger tires and it will cause the error if it isnt compensated for.
  11. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    There is something wrong for sure! my dads 70 blazer with a stock 307 would pull his beast around without any problems. Your 350 should pull your blazer around just fine. First off is it bogging, missing or just no power? have you checked the plugs to see if they are rich or lean? since you have dual exhaust you might need to rejet, might be a little lean now. Is the distributor the original one, whats it from? A revurve would probably help. Have you replaced the fuel filter, checked to make sure no fuel line are bent? Clean air filter? How about the exhaust is the muffler(s) plugged, any of the pipes kinked?
    I would find out why it has no power befor I spend any money on performance parts! When you do get to modifications, I would start with headers, and rejet. The stock manifold should be fine till you get to 250hp or start messing with cams the stock intake should have more torque below 2500rpm than the aftermarket intakes. After this I would run the performer RPM Q-jet (I have found the rpm is just as strong as the performer in lower rpms and pull harder in upper rpms) I have not tried the brand new performer but looks like it might be a good choice. When changing the intake this would be a good time for a cam swap also.
    Good luck
    Shawn
  12. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    nice spam..... :(
  13. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    my truck lacked power ,and it was the muffler pushing against the e-brake cable so check everything
  14. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    i have a 86 that once had a weak 305 and 33's with 3.42 in the rear and it will still go over 90, granted it took 5 miles to get there, it ould still go. check the timing, plugs, and plug wires first off. IF you have a fried wire that is misfiring its hard to tell at idle on a stock motor, but it will kill performance. I had it happen to me once and after I took it to a mechanic i felt like a retard for not checking the them myself.
