K5 Lift Setups!! Post Pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Sep 19, 2003.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    To cutdown on reocurring posts, i thought it would be a good idea to start one specifically for K5 Lift/Tire set ups. Here is the format..
    Year of Blazer
    Suspension/Setup Used
    Actual Height Gained above stock
    Tires youre currently running
    Any other mods, such as fender trimming, drivetrain and steering corrections, and any body lifts etc. Plus Pros and Cons of your setup. Thanks guys..hope this helps
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    What if your truck was never stock or was 2wd in a previous life /forums/images/graemlins/grin.gif
  3. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    There should be a standard way of measuring the lift, like in that post that Watson had going a while ago. I think he had people measure from the axle tube to the lowest surface on the bumpstop mount.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Wow, that was a LONG time ago...
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    That was a good post,I cant remember the title of it though.
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    1973 blazer used 5" lift Superlift softride dodge springs (rear application for a 95 Dodge) moved springs inboard in the rear(I do not recomend doing this) had to make new hangers all the way around springs are about 10" longer in front and I think about 5 or 6 in rear also did a shackle flip in rear total suspension lift 8" or so running 38 radials cut out fenders becasue the tires tuck all the way up into the fenders great flex very little axle wrap good ride and the springs were free! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I found Stephen's old post and brought it back to the top.
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    year of blazer: 85, and its a JIMMY. /forums/images/graemlins/grin.gif
    suspension:
    front: Rancho 4" HD springs + ORD zero rates + ORD HD shackles
    rear: stock springs + UHMW-PE, revolvers, ORD 4" shack flip, rockjunkies spring perches.
    height gained = 5.5" (guestimate)
    tires you are running:
    onroad: 35x12.5x15 ProComp MTs on 8" wide rims
    offroad: 39.5x15x15 TSLs on 10" wide rims
    other relevant mods:
    fender trimming (see webshots), np205, HAD shafts, D60/ff14b, rockstomper x-over, 1" ORD body lift.
    Pros: cheap/simple and relatively low cog for the tire size
    Cons: can't bob/tube the rear with leaves, revolvers could get locked in the open position (hasnt happened yet, they say it can tho).
    pic
    j
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    RIGHT ONE, MINE:
    89 3/4 ton suburban
    4" pro-comp springs and 1" hill4wd shackles front
    4" block ( /forums/images/graemlins/frown.gif) rear
    2" body lift
    36x12.50-16.5 TSLs
    cut fenders
    LEFT ONE, FRIEND'S:
    84 3/4 ton suburban
    stock
    stock
    stock
    stock
    11" difference between the two! /forums/images/graemlins/shocked.gif
