K5 newbie needs help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dodgedude99, Jul 27, 2003.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i had just bought a 1988 K5 silverado yesterday for $700.
    being im new to the chevy trucks (i also have a lifted dodge). if i put bigger tires on or change the gear ratio or both how do i correct the speedo?
    also does anyone now of any online places to get interior pieces? the body on this thing is in really good shape but the interior is just sorta trashed.
    also it has a 4" Skyjacker lift, but it seems like it leans to the right. is that just a K5 thing (my ram and most everyone else i know that has one leans to the left)?
    thanks for any and all help.
    shawn
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    www.LMCTruck.com /forums/images/graemlins/wink.gif This place has EVERYTHING out there that you could need for your K5. Enjoy!
    -Dan
  4. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    There's several posts on body sag just try a search. You might look at the spring itself and body mounts just for starters. For parts, interior and exterior, try these sites. The first two will send you a free catalog but the last one is the only one that carries the rear interior sidepanels. Try doing a search on the speedo, I'm sure it has been covered. Yours is mechanical though, only the 90's and 91's are electric.
    www.chevyduty.com
    www.lmctruck.com
    www.classicindustries.com
    Good luck and welcome to K5's, you won't even miss that Dodge. /forums/images/graemlins/wink.gif
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    You change the speedo gear in the transfer case. Real easy to do. Do a search for "speedometer gear" and you will have a thread pop up that has a guide to all the speedo gears in it.
  6. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    thanks guys!
    a couple of the dudes over at pavement sucks recommended you all.
    im not going to have to miss my dodge, i still have it.
    i started doing that as a show truck, an driving it daily.
    well thats to hard to do both, and its getting to the point that i have to much $ to drive it every day.
    so i got a 1988 k5 with a decent body. it needs 2 doors and a tailgate, a rocker (which was included) and some small patching of the floor. the thing runs great for having 133,000 miles. it already has a 4" lift with rs9000 shocks(the ones with the adjusting knobs on them), so having a trashed interior is no big deal, especially for $700.
  7. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    Body Sag Question
    i searched for previous body sag post and what i had gotten was the bed floor and tail pan was rusted away, that isnt the case on mine. my bed floor and tail pan are new. would bad body bushing cause the lean?
  8. Blazn88
    Blazn88 Registered Member
    Dec 11, 2002
    83
    Northern California
    Re: Body Sag Question
    /forums/images/graemlins/deal.gif..Take a little time and fill out your profile /forums/images/graemlins/grin.gif and welcome to CK5 /forums/images/graemlins/k5.gif
  9. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well you can check those but I would start by ..
    1.Parking it on a level area and then measuring from the ground to the frame by the front spring mounts...That will give you a ballpark on how much it is off..
    2.Then take a measurement from the top of the frame to the top of the u-bolt plate (same place on each side) that will tell you if maybe the spring itself is sagging more then the other one....
    If they are the same then I would check the (not being a smart ass but the tire pressure) then the spring bushings, then thebody mounts last /forums/images/graemlins/thumb.gif
  10. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    yes welcome to CK5. This is the place for info on a Chevy period. Huge list of threads and a great library
