K5 on 2 1/2 tons and 49's
Discussion in 'The Garage' started by micah, May 17, 2004.
  1. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    K5 on 2 1/2 tons and 49\'s
    still some work to do, but he's working to get it done by Memorial Day weekend to make it to TPP II at Katemcy Rocks.
  2. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    Re: K5 on 2 1/2 tons and 49\'s
    Now that's some fender trimming! I like that thing a lot. /forums/images/graemlins/waytogo.gif
  3. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Cool looking K5. /forums/images/graemlins/pimp1.gif
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/yikes.gifthose are some big tires /forums/images/graemlins/peace.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what is he running suspension wise? I see the homebrew shackle flip but lift leaves as well?
    ahh I located the photos on your site. Didn't mention the narrowed front end. Looks like it will be fun.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I think I just found a new friend. /forums/images/graemlins/waytogo.gif
    How can we get more details about this?
  7. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    He has long chevy rears but they measure to be about 60" he says... so not completly sure about those. I do know he did a home brew rear shackle flip with a bit of lift. I know he has 56" springs up front with the long side to the rear. Helps move the front axle forward 3" (I think). He also made custom drop brackets / boxed the front frame for the relocated front spring hangers forward about 4" from stock and down about 3". So stock springs but about 6" of lift I think.
    One big problem was the front axle and it's large top loaded pumpkin / diff and his oil pan / exhaust headers / front drive shaft. By moving the axle forward it put the top loaded diff closer to the front of the motor / away from the oil pan sump. I think he plans on running stock manifolds but not sure what was decided about the routing of the exhaust pipe. With manifolds he can run his square shaft to the high pinion of the rockwell and not hit anything, with headers it was a problem.
    So, I hope I didnt steal any of his thunder but he (Balls of fire) doesnt post up much. Again, I've watched him building this up over the last 6 months or so and know a little about it but not everything.
  8. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    WOW /forums/images/graemlins/yikes.gif
  9. micah
    Sep 18, 2003
    374
    Austin, TX
    the rear springs are supposed to be 63's, but they measure just over 60... they're from a 94 suburban. The front springs are 56's. he made his own mount for the front spring eye of the front spring. The front spring shackle was moved forward in the frame and extended. The rear shackle was setup with a homebrew shackle flip (rear spring, front hanger from a truck).
  10. micah
    Sep 18, 2003
    374
    Austin, TX
    he's actually running long side front.... long side rear would net a 6 inch axle push forward... running long side front puts the axle only 2 inches forward the same as ours with 52's.
  11. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Looks great! But one question, why do people always take pictures of their rigs at night???
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    cause they work all day and when they are finally done and tired its night time /forums/images/graemlins/wink.gif
  13. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    looks good , but picture quality is horrid /forums/images/graemlins/waytogo.gif
  14. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Just save it and [darn] around with the light settings
  15. micah
    Sep 18, 2003
    374
    Austin, TX
    If you two don't quit it, i'm going to pull this car over!
    I'll get you some better pics. So today, we took it out to see if it was trimmed enough... well we should have installed his shocks and/or bump stops first. not 10 feet from the road, we hit a hole and the front end bounced hard enough that the brake line from the caliper hit the crossmember and snapped the fitting.
    not a problem.. we still have rear brakes, right? wrong... turns out the bleed job left much to be desired in the rear... so back to home. Well as he's turning onto the drive, just in front of his house, he doesn't get it turned quick enough (full hydro valve takes a lot of turns lock to lock) and with no brakes he runs head on into the back of his 2001 Dodge 3500 dually. /forums/images/graemlins/doah.gif The front spring hangers nailed the bumper pretty good so its mostly bumper damage except the rear fender where the bumper got pushed into it.
    I didn't have my camera with me but i'll try to get some shots tomorrow.
  16. micah
    Sep 18, 2003
    374
    Austin, TX
    by the way, i have more pics of his truck in my album (link in signature) under MISC...
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ouch was the dually in good condition before he hit it? Lets get some pics of this monster K5 /forums/images/graemlins/tongue.gif /forums/images/graemlins/peace.gif
  18. micah
    Sep 18, 2003
    374
    Austin, TX
    well yeah... it was in great shape.
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    49 XL's are too cool
    I cannot look at my truck anymore after riding in Don's on 49's
  20. micah
    Sep 18, 2003
    374
    Austin, TX
