k5 or burb tank in a k truck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by camiswelding, Feb 25, 2005.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Will the 31 gallon burb/k5 efi tank fit? Without hitting the 14 bolt? I know the 25 gal k5 tank will ...
    Im about to buy a NEW ONE and want to make sure it would fit before I spend the bucks...
    anyone have this setup that I can talk to?
    truck is an 89 v3500 c and c....
    I mocked up the 25 gal k5 tank and it appears to work....
    thanks
    cam
  2. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    i have the 30 gal blazer unit in my truck with 6" lift and 14ff.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I tore out crossmembers when bobbing my frame and dropped in a 30 gallon or so EFI Chevy Can Tank, same size as the K5 tank with a different seam location
  4. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    how much clearance do you have... and do you wheel with it?
    I have a 5 inch superlift on the rig and I can also go a little higher in the frame because the rig is a custom flatbed
    chevy efi "CAN" tank... which chevy is that?
    thanks
    cam
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Sorry, Van tank
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I swapped a blazer tank into a K10. Its ghetto but it works. Its under the bed where the spare tire would be on an original truck. Let me know if you want pics or more info.
  7. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks orion... I have the k5 in a truck writeup so Im good there.... I was wondering if the larger 31 gal tank would work and still clear the 14bolt...
    thanks
    cam
  8. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    So, do you HAVE to mount the burb/blazer in the rear where they are located on the burb/blazer?
    I like where it's located now on my K10, near the middle of the truck. Also that way I could use the stock filler spots.
    Any way to make the larger tanks work with the stoc tank location on the trucks, or am I better off going with dual tanks?
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Anything is possible with a little fab work :thumb:
  10. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    I'd think you would have t-case / driveshaft clearance issues with it near the middle of the truck...
    I am installing one of the larger suburban tanks into my K25, and thus far, it doesn't appear I will have any clearance issues with the 14 bolt.
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    31 gal tank, rear of my 84 Dually (dana 70) Fits fine. The filler neck comes out behind the rear tires.
