K5 Rear Shoulder Belts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k5blazer, Apr 6, 2004.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Is it my imagination, or do I remember seeing rear shoulder belts in some of the later model K5's (like '90 '91 or something)?
    Anyone know if they had 'em?
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Yep they sure do. Not sure what year they started (I think you're right, 90) but my 91 definitely has them.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    SO they are anchored to the top then?
  4. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Exactly, so when ur topless, there's no rear belts. Well unless you bolt some down like me. /forums/images/graemlins/thumb.gif
    Nate /forums/images/graemlins/k5.gif
  5. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    My 1990 has them. I wish it were only lap belts though. What are you guys doing when your tops are off? I want to go soft top, should I just order lap blets for an older K5 from LMC or other company?
  6. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    [/ QUOTE ] thats all i did, just i got them from the local junkyard.. quick cheap and easy /forums/images/graemlins/waytogo.gif
    Nate
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I heard something about the rear shoulder belts bein anchored to the top, like if you rolled, the top may pop off and with the belt anchored to the top, your head may go pop too??
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    So then I would take it rear seat has no retractable belts in it, just 3 fixed lenght belts with latches?
    The reason I ask is I'm trying to figure out what kind of seat belts I want to run in the rear of my truck, I've installed a roll cage so I have an upper anchor point, but my rear seat is from an '89, and has one standard lap belt in the middle, and two retractable straight belts in the seat, that are supposed to connect to fixed lenght sections coming from each outboard side.
    It's kinda of goofy if you remove those retractable mechanisms, because that would leave two 2x2" holes in the seat.
    So if a seat from a '91 has just the lap belt in the middle, plus two fixed lenght belts for the outboard seats, I think I would start sourceing a seat from a '91.
    Ken
