k5 rear window cable
Discussion in 'The Garage' started by beto101, Dec 30, 2008.
  1. beto101
    beto101 1/2 ton status
    Jan 27, 2008
    102
    Phoenix Arizona
    Does anyone know where I can find the cable that runs the rear window? I tried the dealer and its discontinued
  2. 84ever
    84ever Registered Member
    Dec 26, 2008
    24
    North Carolina
    If your asking about the regulator cable that comes from the motor LMC Truck should have it.
  3. beto101
    Jan 27, 2008
    102
    Phoenix Arizona
    That's what I'm looking for. I will look again in LMC. Thanks
  4. dfl701
    dfl701 1/2 ton status
    Aug 25, 2008
    3,137
    Mobile, AL
    not to steal the topic here, but i unhooked my cable to try to roll the window down and it twists but feels like its about to break.? how is it suppose to work? i tried searching but couldnt find anything specific to my question
  5. beto101
    Jan 27, 2008
    102
    Phoenix Arizona
    I use my cordless drill and twist too. It gets stuck and I have to giggle the glass or pick up on it then it works again. It didn't do that befor the cable went bad
  6. dfl701
    Aug 25, 2008
    3,137
    Mobile, AL
    when i used my drill it felt like the cable was gonna break from twisting.
  7. beto101
    Jan 27, 2008
    102
    Phoenix Arizona
    I've had mine twist up several times but hasn't broken yet
  8. dfl701
    Aug 25, 2008
    3,137
    Mobile, AL
    hmmm...ill have to try again cuz i need my window to work
  9. beto101
    Jan 27, 2008
    102
    Phoenix Arizona
    Yeah sucks having to climb through back seat and dig through all my project parts to get to the cable
  10. dfl701
    Aug 25, 2008
    3,137
    Mobile, AL
    yea i know mine wont roll down at all so i cant even get the window down right now to find out whats wrong lol
  11. beto101
    Jan 27, 2008
    102
    Phoenix Arizona
    Maybe regulator is bad. LMCtruck.com does offer those parts if you need them
  12. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    577
    sounds like the cable has some corrosion or something in it not preventing it from moving freely. I'd try replacing that first seeing as it would be the cheapest rout, Then move on to the regulator and rails. I had the same issue about two years ago. I thought the motor was going out, but to my surprise after i replaced the cable and lubed up the regulator it all worked like new!
  13. lectric80
    lectric80 3/4 ton status
    Apr 4, 2007
    9,508
    Grantsville, Ut
    Don't forget, the cable runs to a transmission on the regulator that converts the turns to a gear that then raises the window. You may need to remove the cable from the transmission then make sure it turns. If it turns fine, you may need to look at the transmission and regulator to find the real issue.
  14. Metrodps
    Metrodps 3/4 ton status Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,572
    55
    earth
    This might help you to see whats there.
  15. dfl701
    Aug 25, 2008
    3,137
    Mobile, AL
    yea that helps im gonna try that this weekend, ill prob just take the whole cable off and tear into it from there.
