K5 sliding side windows for sale, few other things.
Discussion in 'Pacific Region' started by dyeager535, May 3, 2005.
  1. dyeager535
    26,980
    Sliders, $50. Underneath my porch, never going to use them. Can't recall if they are tinted or not. Should be in good condition, will dig them out and inspect this weekend if interest.
    Fuel, evap, return lines from '81 K5 frame. Free
    1980 TH350/205 combo. Ran fine, been sitting for awhile, friend is junking the truck itself. $250
    (stainless?) AIR manifold with hose and working check valve $5
    "GMC" or "Chevrolet" horn button for two spoke steering wheels, such as what would be in a 1983 truck. SMALL cracks at bottom edge on GMC, slightly scratched, but still bright. Looks good, but not perfect. $2
    Accel boots for points style cap, with metal crimp on connectors for cap terminals. Brand new. $2
    1980's Astro TBI throttle cable. Approximately 5.5ft long, stock hole in carb/TBI end for stud/clip connection. Will fit truck pedal/firewall, and connect to a carb, TBI, etc. Perfect for custom applications? $10
    TH400 pan gasket, not cork. $7
    Stock SBC oil pan. 4 qt pan. DS dipstick, with fill plug. Cleaned, painted with semi-flat black POR-15. $15
    1 31 gallon tank. Good shape (no dents or major exterior corrosion) no leaks. TBI tank, has broken interior baffle, can be removed easily. No interior rust. No sender. $5
    10 spline 465 in pieces, complete, (MAYBE missing a couple of the loose roller bearings) $20.
    Stock clutch fan. Worked fine, went with electric for the heck of it. It's 7 blade. $10.
    10/12 bolt yoke. Allows you to run 12 bolt size u-joint on a 10 bolt axle...that means no adapter u-joint for older driveshaft, with newer axle.
    Misc. wiring harnesses...
    1981-?? Truck AC harness. (Only one cut wire, Large Rd., fusible link lead?? Will research upon request) $5.
    Power Door Lock (?either that or its for power windows) wiring harness, one side only. Or/Blk/Lt Blue wires. $5.
    Early style (approx. '84 and older) non-weather pack K5 tailgate wiring harness, cab side...(plastic blade fuse only) includes power feeds, switch wiring, ends at connectors just through firewall. $10
    Underbody harness for above, minus plugs on one end. $5
    Diesel warn light harness?? Power feed, blk and Gray wires, 2 bulbs, one two prong weatherpack connector. Yours for shipping cost.
    Truck fuse panel, '81 up(?) two cut wires, easy fixes. Fuse panel labeling in VG shape, column mounted ign. switch included. $40
    1988+ headlight harness, single headlight as far as I can tell.
