k5 update high steer clearance woes, & caddy motor install pics
Discussion in 'The Garage' started by boz42, Sep 2, 2004.
  1. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    here is an update from my build-up.
    I installed a ORD high steer/crossover set-up & a WTO box. i am running a 60f w/ 4" frt leafs & a 1" zero rate, w/ axle moved foward 1.5". The problem was that the pitman arm & drag link end was dirrectly above the tierod & only had about 3" of clearance. I was scared they would hit when the driver front tire was at full stuff. I replaced the dropped pitman arm w/ a straight one & it hit the frame, so i used a lowrider technique & "C" notched the frame to get clearane. I made the "C" notch from a piece of 1/4" wall 6" o.d. steel pipe & welded it in. the straight arm gave me 6-7" of clearance between the pitman arm & tierod.
    the caddy motor is finally in its new home also. i made engine mount out of spring bushing assemblies. my frame is boxed from the rear of the rear spring hangers to the rear of the frt crossmember thet the prop valve mounts on. the mounts are welded to the plates we used to box the frame i made the engine pedistals & the new crossmember out of 2" .120 wall D.O.M. pics from top & under side
    here are 2 pics of us testing the clearance between the drag link/ pitman are & the tierod. it looks pretty good now. didn't flex it out to hard since most of the welds in the engine compartment are just tacked & we didn't want to chance braking them
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Very Kewl!! /forums/images/graemlins/bow.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    woah thats awesome /forums/images/graemlins/peace.gif nice work /forums/images/graemlins/waytogo.gif
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    hey quick question about the caddy motor. My buddy has a 472 in his, and the temp gauge doesn't work. I called the parts stores and they said it has a switch stock not an actual sensor, so do you know what to use??
  5. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    There is a temp gauge sending unit in front of the intake and there are probably two switches one in each head. The ones in the head were supposed to turn a light on in the dash of the old caddy's at 290 deg. Kind of a shut it off now light.
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hmmm yeah the one at the front of the intake is the one we need. Parts stores don't even list them or maybe they are just kinda /forums/images/graemlins/screwy.gif
  7. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    You hit it right on the head. Take the old one out and see if you can visually match it with a Chevy part. They look about the same but I haven't actually checked.
  8. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    boz42 nice work on the fab. What did you do for transmission mounting. Go with the adapter plate?
  9. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    right now the tranny is sitting on the stock crossmember w/ a 203 adapter behind it. i am gonna run a doubler, but i haven't got to the nitty gritty on it yet i am gonna go ahead & put all of the doubler in & see what it looks like, when i get something fabbed up i will post up.
