k5 wants to keep going when i stop?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wraenking, Jan 10, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    when i get to red lights, it suddenly is seeming like the choke is stuck maybe?
    anyone have this happen?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what,idles up high?? or?? just wont stop??
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check to see if the throttle is actually returning all the way back to the idle position when you let off the pedal. A sticking linkage, a bad throttle cable, or a broken/missing throttle return spring can all contribute to this. There should be 2 return springs. One fits inside the other and they attach to the same points at both ends. Make sure they're both installed.
  4. riverbend73
    riverbend73 Newbie
    Nov 25, 2003
    3
    Mankato Minnesota
    I had the same thing happen to me. I don't drive my 91 k5 all that much. On the day that I did the throttle was stuck open. Kinda freaky when in town and your truck is wanting to go 40. This is where it gets weird. I pull into home depot and I pop the hood. The entire top of the engine block around the throttle body was packed with walnuts. Apparetly the squirrels thought it was a good place for storage. So I crawl in and start tossing walnuts out of the truck. People kept stopping asking if they could lend a hand. My reply "No thanks, squirrels just packed my engine compartment with walnuts I should be fine." I did not realize how many people were capable of burn-outs. /forums/images/graemlins/shocked.gif
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Now that is funny, friggin' squirrels anyway. /forums/images/graemlins/rotfl.gif
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hahaha /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    mine was ding this, it had the electric choke on it..started acting goofy and wouldnt shut/close the butterfly when it was suppost, so it would run shitty when it was cold, then when the choke came on it would stay on and would be running at around 1000 when i was stopped at a light or something, so i put a manual choke on it so i could control the choke, when its cold i leave it on and keep it running at a higher rpm like that so i dont stall, then when it gets warmed up i just open it up all the way
  8. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I had a problem once with a brake booster, it idled fine in park, but when you hit the brake pedal, the booster leaked vac and the idle went up, and I only had manual brakes(hard pedal), so until I could fix it, I just plugged the booster vac line, then the idle stayed low, and I just had manual brakes
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    well i will pop her open this morning to see what has happened. hopefully no walnuts!! lol
    int he last month and a half, ivs noticed my choke light would come when i was stopped at lights, then go off once i started going again. if it is the choke, i like the idea of a manual one. is it a pain in the ass?
    oh yeah...............
    NJ DMV sucks!!!
    i failed for the second time on my emissions. 1st time i scored a 2900, this time after changing the egr valve and pcv valve i was down to 2400, i need to be around 2000
    any ideas
    did i lose all of you?
    thanks guys /forums/images/graemlins/thumb.gif
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    pretty sure it probobly is your choke, i just didnt feel like finding out why mine was acting wierd, and liked the idea of being able to control it better. there a sinch to put it, you can by the "help!" kits for a manual choke conversion for are carbs...got mine at pepboys..
