K5s w/ 6" lift help me out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Jan 22, 2003.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    K5s w/ 6\" lift help me out
    In a Blazer (1976) equiped with a V8, th350 and 205 fixed yoke and 12 bolt (preferably cv shaft equiped), what's the d-shaft length if you run this set up??
    Now, on a Blazer equiped with the same stuff and a 14 bolt, what's the length?
    trying to budget this darn project and this will let me know if I can run what I have for a while before I tear into it.
    I have a 2" add-a-leaf and 3.5" or 4" tapered blocks and need to aim the 14 bolt pinion at the t-case output anybody know what degree shims I will need?
  2. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Re: K5s w/ 6\" lift help me out
    Come on now! help a brotha out! /forums/images/graemlins/1zhelp.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well when I did mine I called Tom Woods driveshafts and he asked me what I had and he figured it out and sent me the right length so I don't know.
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    hey brother,
    I don't have any numbers for you but i know this. A 12bolt is the "shortest" pinion, and the 14 bolt pinion is the longest. So, depending on how much flexing you do, a shaft length might be needed just for the axle change. I'm sure you could limp around town with a shaft the wrong length though. Ex: get one a bit short made until the 14 is swapped or ex.2 just hang on to that 12 shaft and wait to get one made until the 14 goes under.
    Something like that....
    the pinion angles must be measured on every truck.
    Blake
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i'm about to swap a 14b under truck, from a 12b. think my shaft will still fit? it was about 4" too short fully closed.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    my recomendation- you'll probably have to move the perches as it is, so why now just weld them so you have a stright pinion angle? that's my plan. if you don't have to move the perches i would reccomend the extra work anyway. they aren't expensive if you don't want to reuse the old ones.
  7. ColAdo82K5
    Feb 18, 2000
    789
    MO
    It will probably bolt up as is, assumming you change to a conversion ujoint. But you will have little to no compression travel on your shaft and your rear suspension. If you take a good bounce on your rear, your shaft could bottom out and crack your transfer case of something crazy like that. It all depends on how much you can flex and how much you actually do it. You will have to measure to make sure though.
    Blake
