Keep blowing brakelight fuse!!! help
Discussion in 'The Garage' started by chevyfumes, Jun 3, 2006.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    There must be a short somewhere, is there anywhere I should check first,before I tear my entire truck apart?:confused: :o
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Light sockets
    Brake light switch
    The rear harness connector
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    cool thanks
  4. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    check the trailer connector , I think thats what you call it
  5. chevyfumes
    Feb 24, 2000
    38,584
    266
    ooh good point,thanks, I dont ever pull anything but it does have a crusty connecter on it....I bet thats where its coming from...
  6. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    i Second the trailer wiring harness. Normally, they form a T and plug in between the right and left side brake/turn harnesses. If you don't ever pull anything, just remove the T in teh middle. If you still want it, i reccomend the Uhaul ones.....they have good diagnostic indicator lights on them. Good luck!
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    I just went out to the Blazer to just look at it real quick and I have 2 plugs and someone has pulled all the wires out and messed with them, this should be a simple fix, thanks again guys...
  8. mrhoes
    Jul 20, 2002
    123
    Austin, Texas
    I learned that from when my turn signal lights kept blowing, I checked the trailer connector and it was starting to melt.
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Holy crap...You actually have a k5...and work on it...:eek1::haha:
  10. chevyfumes
    Feb 24, 2000
    38,584
    266
    I've even written a tech article, I'm still waiting for my wrench...:p:
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    That right aboot the soft top...Damn your more than just padderific:D:haha:
  12. chevyfumes
    Feb 24, 2000
    38,584
    266
    I am padistically motivated...
