Keep blowing fuel pump fuses
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Jun 24, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I've blown the fuel pump fuse acouple of times in the past, but today it blew 4 times in 5 miles or so. Had to keep robbing fuses till nothing else worked, but we got home. Need to pack some extras, but I really need a cure. Any ideas?
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Sounds like a fuel pump to me. You might try and see if you can find any shorts, but it's prolly the fuel pump.
    <font color=purple>Have you hugged your K5 today?</font color=purple>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    When did you last change the fuel filter? A lot of resistance (from clogging) can also cause that problem.............if not, sounds like either the pickup screen is clogged or the pump is going 'hooters' up..........no offense ladies! [​IMG]
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  4. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    It hasn't been that long since the filter was replaced, probably less than 5000 miles. But I know the mechanics at the Chevy dealer I worked at until recently said that the quality of gas really went down the crapper last year when the prices started going up. They did more injecter cleanings last year than ever before.
  5. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Have you messed with any of the wiring lately? If the fuel pump wire is touching a ground it will pop the fuse.
    CB
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 38" TSL's on steel wheels
    <A target="_blank" HREF=http://www.azk5.coloradok5.com>http://www.azk5.coloradok5.com</A>
