Keep blowing upper rear ujoint!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Oct 31, 2001.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I keep blowing my upper rear u-joint at the transfer case. I'm only running 4" of lift, the tcase output shaft and the yolk are parallel with each other, I've got a little concern over the driveshaft being balanced which is the aproach I'm heading down now. Everything at the tcase and yolk are in good shape (bearings , seals , etc.)What else could cause this? I always get the greasable kind and keep them greased up but this is getting rediculous ( second one in one week!)
    Three 4-6 foot air launches and not broken yet! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    2 in one week?
    Maybe it's the 4 - 6 ft air launches [​IMG].
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yeah, I suspected that with the first one.. but I've been strictly commuting this week, and they still keep blowing. I should change that to 4-6 foot air and only one u-joint! [​IMG]
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Nah... Ujoints don't count [​IMG].
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are the ujoints breaking or just overheating? The u-joint should move very easily in both planes if it's installed correctly. If you have the bearing cups pressed against the end of the cross shaft, then the joint will overheat and burn out the grease pretty quickly.
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    When I replace them, the movement is firm but not stiff (cross to cap). Over a few days, a vibration will develop and I can see the cross busting the caps out the inside of the retaining u-bolts of the transfer case yolk. I recently replaced the t-case yolk due to previous damage(nearly pogo'd when it gave), new retaining u-bolts and u-joint.
  7. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    just a suggestion: make sure the cap of u-joints are inline with the u-joint caps on the other end of the drive shaft. also if your driveshaft is bent, just enough to change the balance; you will dust your u-joints.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Check out this thread: <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=112382&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=112382&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
  9. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I completely twisted my drive shaft once, so I had a new one made. After I installed it I keeped ruining u-joints. It ended up being a bent transfer case yoke and me tightening my u-bolts too much. good luck.
