Keep braking my drive shaft
Discussion in 'The Garage' started by muddflow, Jan 5, 2006.
  1. muddflow
    muddflow Registered Member
    Dec 23, 2005
    11
    so cal
    Hey guys sorry to bug but, need help. I keep braking my driveshaft(u-Joints) of my 73 1/2 ton blazer. I have an 8 inch lift with 38s. Im guessing thats why:o Im looking for a 14 boltFF but haven't found one yet. until i find one at a decent price what will i have to do to run my 12 bolt. thanks in advance
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Have you measured your driveline angles? Sounds to me with the lift that you are just killin your joints then the 38s are taken em out.
    Ira
  3. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Which end are you breaking it more at? The axle u-joints, or the transfer case u-joints? Is it the front driveshaft or the rear?
  4. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    That's what came to my mind too.
    Inu
  5. muddflow
    Dec 23, 2005
    11
    so cal
    at first it was the on at the axels then just the other day the on from the trnsfer case broke
  6. muddflow
    Dec 23, 2005
    11
    so cal
    Should I try droping the trans. a little bit
    sorry the rear
  7. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    Yeah, your driveshaft angles are too steep. Another thing you could try is rotating the axle up, and that would require modifying the spring perches.
  8. muddflow
    Dec 23, 2005
    11
    so cal
    is there any pads(shims) something like that i could use? My front axle has some shims that really change the angel.
  9. muddflow
    Dec 23, 2005
    11
    so cal
    Thanks for the helpful imformation everyone.
  10. muddflow
    Dec 23, 2005
    11
    so cal
    What about the 12 bolt? should i be good for a while? after i change the angles. Or should i just wait 'til I get the 14 bolt
