keep factory dual front shocks or throw one out?
Discussion in 'The Garage' started by begiles1, Jan 19, 2003.
  1. begiles1
    begiles1 Newbie
    Jan 9, 2003
    4
    when i go to a 4" lift should I buy two extra shocks for the front, or just put on 4?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would just go with one. It would ride stiffer with two.
  3. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Yeah, id go with one only as well.
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If you tow keep the dual shock setup, otherwise ditch it. The dual shocks limit travel.
    Dan /forums/images/graemlins/burb.gif
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    if you buy the shocks to put into a dual shock setup,you have to buy a shock specifically designed for a dual shock setup.they have less dampening per shock but they handle the load much better for a longer amount of time before they heat up the oil inside the shock.so they will most likely last longer than a single shock and give you better dampening over rough terrain at speed.
  6. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I dumped mine. The ride was way better after too. /forums/images/graemlins/thumb.gif
  7. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I decided to ditch the quad shocks on my stock K5 and the ride is a lot better. I should have done it sooner /forums/images/graemlins/rotfl.gif
  8. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Same here, went from 2 rs5000's on each side to 1 sx8000 on each side... wow, much better ride!
