Keep losing my nuts...
Discussion in 'The Garage' started by tRustyK5, Apr 20, 2005.
  1. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Anyone else have the perpetual loose parts? On my truck the t-case crossmember bolts have come loose 4 or 5 times now. A month or two ago I lost a couple on the trail and eventually had two bolts left and no nuts with the tranny/t-case hanging. Lucky for me my buddy Stan has sharp eyesight and found most of the stuff that dropped along the trail behind me.
    Today, I had this weird vibe as I was driving, and the shifters seemed to move more than normal. I got home and one side of the crossmember is just hanging (nuts gone...) but the other side is still tight.
    I figured maybe some new hardware will help, so i just replaced it all with new 7/16" fine thread bolts, flat washers, lock washers etc etc...then torqued the hell out of them. We'll see if they stay tight this time.
    Just seems weird, nothing else compulsively loosens itself...:confused:
    Rene
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I had the same crossmember problem, and the steering box too. I finally just slapped lock tite on them all and tightened them excessively. If they ever come loose again, I'll try double-nutting them or using pinch-lock nuts.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    All this double nutting and pinching sounds like its gonna hurt :grin:
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    ahhh, i doulble nutted once, i was all locked up for a week......
    anyways, locktite cured my loose nut problem. The only time i curse locktite is when im on the trail with hand tools trying to figure out why everything is so darn tight to come back out.
  5. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    I need to get my mind out of the gutter! :grin:
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    nothing better than finding an important part in the middle of a trail.... like a crown nut or something.... or a shackle... i always have a good giggle
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Sounds like a personal problem to me. :haha:
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    lol, same thing happened to me... 2 t-case x-member bolts came off the passanger side and the x-member was hanging from the 2 on the drivers side... at 60mph+ on the hwy. Dont wanna think about what would have happened if the other two had come out. My front driveshaft was hanging by 1.5 bolts too. doh!
    anyway, all-metal lock nuts should work... if not, time for them + loctite. I agree its pretty annoying when parts keep rattling loose...
    j
  9. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I always have bolts and nuts come loose. Of course I'm always re-using used bolts and nuts.
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Well, fortunately the tranny/T-case can only drop so far before the motor hits the firewall...:blush:
    We'll see if these bolts stay tight and don't drop, if they do loosen it's time to get medievel and go with the prevailing torque lock nuts and lock-tite. Unfortunately I couldn't find exactly what I was looking for tonight. They had 7/16" bolts, but only in fine thread (which is better IMO) but the only locking nuts they had were all coarse thread. :crazy: So i used lock washers instead.
    Rene
  11. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    safety wire those things.
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    get a castle nut and drill a hole for a cotter pin to sit :grin:. better yet, just weld the nut on there, it won't come loose...ever ;)
    i can't think of anything ever coming loose, maybe its because i get trigger happy with my IR impact :grin:
  13. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    yea i've had that happen usually i catch it before the bolts fall out bacause you can hear the crossmember bang against the frame when you step on the gas just tighten the hell out of it then go ripping through the bigest mud hole you can find then don't wash it for awhile :D that usually holds them in for a bit :laugh:
  14. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Someday...
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I use Locktite blue on almost everything. Just a little, not soaking the threads. Sometimes removal can be a PITA, but stuff quit falling off.
  16. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    On one trip I was looking forward to, I lost the bolts out of my steering box/ frame. One was still sitting on the frame, another barely in by a few threads. We found another bolt that worked but I had already blown out the rag joint. Now, I have blue loctite and orange RTV next to me any time the wrenches come out. It's easier to carry a breaker bar than finding nuts and bolts on the trail.
  17. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Rene,
    Do you still have the stock "spacers" with the bolts or are you just using regular bolts and nuts?
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Damn, I bet D isn't too pleased with your loose nuts! ;) LOL Ok, I coudln't resist.. :haha:
    Anyhow.. I'd look into some Stover lock nuts and some red Loctite! :D Could it possibly be your frame flexing them loose?
  19. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What grade of hardware is everyone using for the crossmember, Grade 5 or 8. Could be the bolt is stretching, then when there is no tention on the nut it backs off.
  20. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have had the passenger side come off twice now. HMMM that is sorta wierd everybody had the same problem. The first time I was wheelin kinda hard on the throttle when I discovered it. I was worried I bent the dist or something. I have since put pinch nuts on and haven't had any probs, but I am puttin my x-member back up above the frame soon so that should take care of the prob. :D
