Keep my 80' or buy an 87' - 91'?
Discussion in 'The Garage' started by anatomiczero, Dec 5, 2002.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    Keep my 80\' or buy an 87\' - 91\'?
    I have an 80 Jimmy. I bought it for $2,000 from my parents. Right now it has:
    - No carpet or rear sidepanels
    - The tracks and rollers for the front windows are in bad shape so the windows are hard to roll up.
    - The windshield leaks a little
    - Front fenders have cancer, trimmed one so far
    - Recent transmission rebuild
    - 6 yr old GM crate engine, sounds a little weird, like a pinging from the oil pan area and dies if I don't give it gas after I start it up in the morning.
    - Painted half flat black so far, rest is gloss black
    - Lots of holes in body from removing trim
    - Roof over cab flexes easily when pressed
    - etc, etc.
    I was looking at Blazers on Ebay and I like the nice interior, overdrive transmission and fuel injected engines. I don't plan on doing "hardcore" off-roading, not anytime soon anyway. So I figure I spend $5,000 on a nice Blazer and put a little bit of money into it. Or I could put money into my Jimmy, but it needs a good amount of work. /forums/images/graemlins/confused.gif
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1039114784anatomiczero">
    80' or 87-91' K5?
    <input type="radio" name="option" value="1" />Keep the 80' Jimmy
    <input type="radio" name="option" value="2" />Get a Nice 87-91'
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    Re: Keep my 80\' or buy an 87\' - 91\'?
    like the old commercial says "both" /forums/images/graemlins/grin.gif
  3. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I would get an 89-91 K5 cause of the fuel injection, serpintine belts, OD trans (if it is going to see the hwy) and less likely to have rust (if it is from the south or west coast). The fuel injection would be the number one reason for me just don't think I could live without it. Just my .02 worth /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    keep the 80, you have an allowance of $3k that you can make/modify the existing blazer anyway you want. most likely your going to buy a late 80's and have to dump money into that one too. you might as build it the way you want. just my $.02 ...and you cant beat the rare 1980 grille!
  5. anatomiczero
    Jun 26, 2001
    418
    Washington
    It's definately going to see the hwy, it's going to be my daily driver. I think I will get a newer one, I might keep the Jimmy, but most likely sell it for $2,250 OBO.
  6. anatomiczero
    Jun 26, 2001
    418
    Washington
    Edmunds.com says a 90 Blazer with a 350 gets 17-21 mpg and has a 31 gallon tank. Is this true? Or does it get more like 13-17 mpg?
  7. anatomiczero
    Jun 26, 2001
    418
    Washington
    I figured out my budget, If I save until this time next year I'll only have about $6,000 or so saved (depending on my next job) That's with $100 a month play money, so maybe I'll just stick with my 80. How do these upgrades sound?
    3.73 gears
    new front springs/ 2.5" lift possibly
    33x12.5" BFG A/T
    Engine tune up
    Possibly tint my windows (flat black truck with tinted windows, lifted with bigger tires sounds kinda cool )
    Then I could do a custom interior when I make more money and possibly a tbi swap.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    For a Blazer, this is a tough call. Those years are a mix of good parts in the wrong year vehicle.
    For example:
    An '80 Blazer has the highly desirable 205 t-case. It also has a 12 bolt rear end, which is stronger than a 10 bolt.
    The V-series Blazer have the TBI and much nicer and cleaner interiors. The grilles also look better ('89-'91).
    So, its kind of a mix to decide which you really need or want.
    My preference would to get the V-series and swap the rear out for the 12 bolt.
    Swapping the 205 into the V-series can be done, but a few mods need to be done first.
    I was looking at an '80 Suburban a few months ago, a 3/4 ton version with a 350/400/205, 10 and 14 bolts all for $1500, running, but with a rusty body.
    Then a friend of mine told me about an '89 Sub he got from a customer with a locked up 350. This Sub is a 3/4 ton also. It was totally rust and dent free, too. Went and looked at it immediately bought it because of the TBI and the fact it had a 350/400/241, with 10 and 14 bolts, but the rear being a semi-floater.
    The '89 also has a way nicer and better interior than the '80 and also the 3rd bench seat.
    So, which one did I buy? The '89 of course. Even for $750 and a locked up motor, its still a better deal for me since I can install a new motor and have a more reliable truck...mainly because of the TBI. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  9. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    Remember to take it one step at a time, all at once, and start getting lost on what part goes here and what is that for??, the 1980 is a rare item indeed, saw one at the junkyard, you are lucky to have one of those. As said of the 89-91 models, yeah great fuel injection and so on but thats newer and more expensive depending on mileage and where has it been.
    No matter what you buy, you're going to put money into it.
    There is no such thing as a perfect mechanical blazer, there is always some small problems with them that can be corrected with a small amount of money.
    Sometime those flaws could lead to a bigger problem later.
    Check the cab and make sure it's sound usually the biggest hum bug thing is the cab thats full of holes, I learned my lesson the hard way on my 78, redid the whole front only to find out that the cab was shot.
    Engine and suspension would be the other catagories to look at, but they can be changed easily.
    I don't know if this is any help to you but from experience in working on my blazers, I'll still learning more about them.
    Michael /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  10. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    No brainer... 87-91. Cruise-A/C-Tilt-Power windows-Power door locks-F.I.-O.D. ect... Those things are nice to have for a daily driver. Keep the 80 for a trail rig &amp; a newer one for daily service. /forums/images/graemlins/thumb.gif
    Jim
  11. anatomiczero
    Jun 26, 2001
    418
    Washington
    My truck is pretty solid, no rust in the cab, tailpan is good etc. The only rust is the front fenders and a few areas that I took care of.
    Keeping mine as a trail rig sounds like a good idea, so I'll just fix it up and in the future get a newer one for daily driver. The Jimmy has been in the family for about 9 years so I'd like to keep it, and hearing the 80 is a good year is nice to hear /forums/images/graemlins/ears.gif
    Thanks for the replies guys.
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    82-91 Blazer or Jimmy with 6.2L diesel /forums/images/graemlins/thumb.gif
    Fuel injected, Overdrive, *and* 20 MPG. Good year range to improve the selection and price. Most diesels seem to have all the options and nicer interiors.
    With the GM diesels, people either love 'em or love to hate 'em. Chance of a deal from the latter of the two. /forums/images/graemlins/grin.gif
