keepin it clean
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jul 29, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    what do you guys use to clean mud and crap off the underbody?
    after a hard day in the mud, my engine bay is a mudpie...usually the degreaser at the car wash will take care of things but there are so many little knooks and crannys under the body to clean....how do you all do it?
    spray bottle and a toothbrush?
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I just use a pressure washer at home. Depending on how much mud I've caked on, sometimes it can take me 2+ hours to get it all off. I just drive up on ramps and start washing. If you do a lot of muddin you might want to buy a cheap pressure washer so you don't have to drop tons and tons of quarters in at the car wash.
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I take it to the carwash and feed the machine 6 quarters for 3 minutes. I then clean the body and frame with it with the only intention of blasting the clumps off.
    I then take it home and clean it with the garden hose. I live in the city now and have 75-80psi of water pressure so it can blast stuff off pretty good. It's a real blessing when you used to live in the country and 45psi was a lot of water pressure. Anyway, I just take my cloth mit, my tire brush, my parts washing brush, a can of Basin, Tub & Tile cleaner, and a bottle of Dynamo out there and clean it. Wisk does a better job of cleaning but it has salt in it.
    If I'm really serious about cleaning I'll use a toothbrush as well but 99% of the time the parts washing brush does the trick.
    Basin, Tub & Tile cleaner is 10x better at cleaning than engine degreaser. Scrubbing Bubbles is almost as good. Just like engine cleaner, it will kill the grass if you use a lot. The only difference is that it doesn't have an oily texture to it like engine cleaner.
  4. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I saw some silicon based (I think) spray advertised on Trucks! TV... I didn't get the product name or maker though... This stuff supposedly is just sprayed on the undercarriage, and is periodically reapplied after wheeling and washing. As I understand it, this stuff allows you to basically "rise" off the under cartridge with a water hose...
    I'll try to check their web-site for info...
    I'll let you know what I find out...
  5. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I e-mailed Trucks! TV for info.... but I'm not gonna hold my breath for a response....
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    If you are Lazy like me...Get a sprinkler with adjustable spray patterns set it on top of the tires for about 30 min each then set it underneath. If it doesn't get it all off it will at least soften it enough to knock it off with a garden hose /forums/images/graemlins/thumb.gif
  7. tecton
    Dec 1, 2002
    1,553
    WV
    hahaha
    i like that sprinkler idea!
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Lol Me too! /forums/images/graemlins/rotfl.gif
  9. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I try to spray vegitable oil under my truck before I go playing in the mud works real good when It comes time to clean it.
