keeping headlights and grill on frontend taper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dr_moneypit, Aug 3, 2004.
  1. dr_moneypit
    dr_moneypit Registered Member
    Jul 29, 2004
    23
    lonestar state
    I would like some info on how to taper frontend and keep headlights and grill
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Unless you want to taper it 1" each side, you will have to lose your headlights and mount them somewhere else. Some guys have put there lights on there bumper, or in custom mounts on the hood. Where ever.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    steve is forgeting about Sandmans K5. matt tapered his like 9"-10" per corner and he still runs normal headlights and a narrower grill.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    yeah, but they're not in stock position. Maybe I mis-read what this guy said.
    But if your asking if you can re-use the stock headlights, in a different place, yes. in the stock place, no.
    Sorry for the confusion /forums/images/graemlins/doah.gif
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    his are still on the stock location on the core support IIRC. just all the area between them has been narrowerd and opened up for airflow.
  6. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    I managed to retain the factory headlights in the factory core support as well. Just cut a chunk out of the center. Like so.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You mean like this?:
    I cut the headlight buckets out and then cut off the metal I didnt want. I then bolted the headlight buckets back on to the core support.
    Its something that you figure out as you go. There isnt like a measure and cut there type of thing. I lost 9.5" off of each corner and I didnt see a way to go narrower and keep the stock heater setup. My fan moter hits the inside of my skinned out fender.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Matt what is your outside measurement from fender corner to fender corner on the front.
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    opps sorry, ignore me then /forums/images/graemlins/thumb.gif /forums/images/graemlins/doah.gif
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Measured from the outside of the grill end to end is 52". I measured it there as the fender itself is difficult cause of the rounded edge.
