Keeps eatin Ujoints...Pinion bearing?
Discussion in 'The Garage' started by Lotsa_Faith, Feb 1, 2005.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    I've been going through at least one back ujoint every two weeks. About 5 months ago I put in a new pinion yoke since the old one got tore up when a driveshaft broke, and about 3 months ago it started doing this. The angle isn't the best with the 4" lift, but I had it like that for a year before it started eating joints every 100 miles. How do I go about replacing the bearing?
  2. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    When you replaced the yoke did you replace the crush sleve on the pinion shaft? Did you check the in/lb resistance on the pinion durring install? there are 2 bearings on the pinion if you have a 10/12 bolt, one just under the pinion seal and another that needs to be pressed on and off at the base of the pinion.
    Good luck!
  3. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Why do you want to replace the pinion bearings? Do you think something hurt them? Pinion bearings won't cause your u-joints to go bad...
    I guess I realy don't understand what replacing them has to do with your drive shaft issues. :confused:
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would bet your driveshaft is out of balance from hitting the ground and that's why it's eating joints.
    If the joints don't fit tight in the driveshaft, they'll also wear out quickly.
    You are fully greasing the joints upon install and smacking the yoke with a hammer to make sure they move freely, correct?
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Check to make sure you didn't bend the driveshaft as well when you broke the yoke. A bent driveshaft will eat u-joints like you are doing. Also, I don't know how likely this is, but make sure that the pinion is not bent, and that the yoke you put on is not warped or crooked.
  6. dyeager535
    26,982
    191
    When I bought my truck I was throwing u-joints about every two weeks. I noticed after the 3rd one that the straps on the yoke were screwed up...the previous owner had put the straps over the c-clips on the yoke caps, which warped the straps, and allowed the yoke to move a bit under load.
    Of course, that "walking" ruined the yoke, which I also didn't notice until the next u-joint went.
  7. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    Whats the deal with hitting the yoke with a hammer, i've never heard of doing that before and I haven't ever done it. I thought maybe by changing out the yoke, I didn't torque it correctly so there could be some play in it (even though it doesnt seem to have any when I check it) thats why I thought the bearing might be bad and allowing the yoke to wiggle. It sounds like my driveshaft might be out of balance from smacking on the ground. I'm at school though right now so I'm just gonna have my dad take it to a driveshaft shop and take a look at it when I get the tranny back in.
  8. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    Anyone got any input?
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Do the trunnions of the joint move freely in the caps of the joint? There should be no resistance to the movement of the joint.
    If they're greasable, you are greasing them before you drive on them, right? The grease they come with are pretty crappy grease. Ignore this if you use solid joints.
    You also need to make sure that the caps are held tightly by the straps. Don't forget to put the clips on the caps or else the joint will wander.
    I eat joints every 3-4 months but it's due to my bad driveline angles.
