ker klunk, ker klunk, ker klunk..........UH OH
Discussion in 'The Garage' started by wraenking, Nov 1, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    well, thats what im hearing when im driving now. i thought maybe it was bearings, but i lifted both the front end and the ass, and all the tires move freely with no noise. i shook the hell out of the u joint and it doesnt seem to have a lot of play. is there another way to check it? or is this noise something else completely?
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Its not an engine knock is it?
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    no, i dont think!!! i just puther in and she purrs. my buddy on the phone said maybe the u joint, but i cant really tell. it sounds like a heavy metal clanking
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Ball joints?
  5. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    did you just say that you lifted the truck ?
    check your clearences on your front driveshaft with
    either your cross member or exhaust.
    does it do it all the time or just when you hits bumps ?
  6. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    i didnt lift it yet, i have rebuilt 3/4 tons in the garage witht the lift and 35's, so if an axle is really screwed, i have an out. but i just pu the motor in and just wanted to drive her for a while first. im stumped
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Last time I heard that sound it was the ring and pinion in my 10 bolt.
  8. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Do you have a part time t-case? If so maybe you could pull the rear shaft out and drive it with the front only..try to narrow it down and vice versa. MAybe be have a friend walk next to you to see if they can tell what end of the truck it's coming from
  9. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    jack up all 4 and throw it in 4 and let iot run listen for the noise /forums/images/graemlins/laugh.gif
  10. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    A worn case in my vans 10 bolt rear end made that kind of noise,mostly when coasting around corners--the side gear ate the diff housing and egged it out so the axle and side gear could slop around some.I thought it was u-joints when I first heard it in nashville on vacation in 92 so I bought new u-joints so I'd have them if one failed on the way home-never changed them for nearly 2 years(didnt use the van that much)but after I did,the noise didnt go away--it soon got worse--so I bought another complete rear end.No noise now!. /forums/images/graemlins/crazy.gif Hope its an easy fix for you. /forums/images/graemlins/laugh.gif
  11. bandit1
    bandit1 Registered Member
    Sep 17, 2004
    51
    Stockdale Texas
    i'm gonna have to bet on ball joints thats what was up with mine too
  12. socalslider
    socalslider Registered Member
    Jun 21, 2004
    71
    Oceanside Ca
    same thing just happened with mine, I lost 3 teeth off the pinion
