Kert's shackle flip
Discussion in 'The Garage' started by 78Suburban, Jun 13, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    How much more lift would I get if I went with 6" shackles instead or the regular size? I'm thinking I would end up with 4 3/4" lift out back, right? Would the longer shackle make my pinion point even farther up? I'm worried it might actually end up being pointed too far up, because I'm putting it on a burb, which has a longer driveshaft than a blazer, hence less of a need for pinion angle corrections when lifting.
    I have 4" RC springs and zero rates for the front. Is it possible I can use the flip with 6" shackles and not have a saggy butt? I would rather not have to take the u bolts off and fool with a rear lift block or zero rate, if I can help it.
    thanks,
    James
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    However much longer the shackle is from stock will raise the truck half that distance.
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Ok, i have his shackle flip(4"), his 6" shackle...and a zero rate(1") And i sit slightly higher in the rear than my front 6" leafs. It will give you right about 5" of lift.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Absolutely awsome, that's exactly what I was wanting to hear.
    What's your pinion angle like?
  5. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    My angle with stock perches on my 10b is slightly lower than pointing right at the tcase. It might be a lil high for you being a burban, but nothing some small shims run backwards cant fix imo.
    I think you should run it how it is. and see how it looks, and if you need shims, then order some.
  6. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
