Key Fob for 95 Suburban
Discussion in '1992-Present Chevy & GMC models' started by Yohinan, May 22, 2003.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    I recently purchased a 95 Suburban 1500 4x4 that is fully loaded. I was under the impression that it should have come with Key Fob's to open the doors vice having to use the key everytime. Can anyone tell me for sure if it did come with the Fob's and the previous owner somehow just lost them and thats why I dont have them now. Is there any way to know for sure whether or not I should have them? Thanks for the help. John
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    It might be in your RPO codes if it came with the keyless entry. Check your glovebod for them, but I don't know what the code would be. Go to the dealer, they might be able to tell by the VIN. If it's loaded then its a good chance it did. But when did the keyless come out for the trucks?? Maybe it wasn't an option yet??
  3. LandRaider
    LandRaider Registered Member
    Mar 18, 2003
    8
    Ocean Springs, MS
  4. Suburbanite
    Suburbanite Registered Member
    Dec 1, 2001
    74
    Florida
    One quick way to find out if factory keyless entry is installed in your truck is by grounding pin G on the DLC (Data Link Connector, AKA ALDC?). The DLC is sorta located down from the steering column. Should be a 12-pin connector for your truck & pin G is located at the bottom left corner. It's the same connector where codes are obtained from. If you don't hear the doors unlock/lock (or vice versa) when you ground pin G then you don't have the factory control module necessary for factory keyless entry. That, of course, assumes that the control module is working. I've never heard/read of them failing so if it's installed the test should work.
    Oh yeah ... if the doors do unlock/lock then you can buy remote fobs on eBay Motors -- that's what I did -- bought 3 & they all worked. 2-button or 3-button will work but with the 2-button you'll have to press the 'unlock' button twice in order to unlock the rear barn doors or tailgate/hatch. If you buy used, either on eBay Motors or elsewhere, the only thing you'll have to look for is "MODEL/FCC ID: ABO0104T" (the 1st 3 characters are letters: A B & O [oh, not zero]).
    Good luck.
  5. Yohinan
    May 21, 2003
    103
    San Diego
    Well I managed to write down all the RPO Codes from the glove box down and looked them all up. A few of them I was unable to locate but I did in fact find the code of AUO-Lock Control, Remote Entry-Keyless Entry (Domestic) so I do in fact have this option. I guess the previous owner missplaced them or the dealership I bought the Sub from just decided they needed them more than I. I guess I will just call my good buddy Dal and see how much he sells them for new. Thanks for all the help. John
