Key ignition getting hard to turn to 'off' position
Discussion in 'The Garage' started by MilpitasK5, Dec 10, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Key ignition getting hard to turn to \'off\' position
    My key ignition swicth is getting hard to turn to the off position. Can I spray it with WD-40? If so, where do I spray it?
    What else could I do to loosen that up? /forums/images/graemlins/1zhelp.gif
    Thanks,
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: Key ignition getting hard to turn to \'off\' position
    <font color="green"> A little lube might help it for awhile. I have a new lock cylinder that you can have if you want. They're kind of a bitch to put in but really should take only about 20 minutes. I bought it for my truck about 3 years ago but it was the wrong style, it's the one that needs a bolt, mine has the little spring loaded pin. I think the bolt one is for later trucks, but I'm not positive... </font color>
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Keep drivin ??? /forums/images/graemlins/thumb.gif /forums/images/graemlins/1zhelp.gif
  4. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Right on Evan. I'll take you up on that! Hopefully it'll be the right one. 20 min. installation will become a 2 - 3 hour with my luck! /forums/images/graemlins/eek.gif
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I'll definitely keep drivin'!!! Too much of a whiney post, huh? /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Swap the lock cylinder out ASAP. I had one jam solid and couldn't start the truck. /forums/images/graemlins/shocked.gif You'll need a steering wheel puller and a lock plate tool to do the job. Once the lock plate is removed it's pretty easy to change the cylinder. /forums/images/graemlins/cool.gif
  7. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    a lock plate?
    I need to replace teh key cylindar and know I need apuller but what's the other one?
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There's a steel plate under the steering wheel that has notches in it. It's what locks the wheel in place when the key is in the off position. There's a beefy spring underneath it which makes it damn near impossible to reinstall it without the lock plate tool. /forums/images/graemlins/frown.gif I've got a nice lock plate tool set made by Lisle that I got for around $20 at an auto parts place. /forums/images/graemlins/cool.gif It makes the job VERY easy. /forums/images/graemlins/thumb.gif
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
  10. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Hey Chris it's not a hard job at all. I replaced my ignition about 2 months ago. I bought a lock plate removal tool for $13 bucks @ Scott's (4X4HIGH) work. Took me about 15 mins to start to finsh. /forums/images/graemlins/tongue.gif
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    No, nothing about a whiney post, I'm saying, if ya can't shut it off, just keep driving !!!! /forums/images/graemlins/grin.gif
  12. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Right on everyone... I probably should do it this week end to be on the safe side. Shaggy says he might be able to let me use his puller and hook me up with the cylinder too! How cool is that?!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  13. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    you know i had a similar problem, but after replacing the key lock switch. I found the ignition switch under the dash right on top off the column to be busted. Mine was ruined because of a electrical short, and it made it hard, even impossiable to turn the key. After taking it apart i can see that it can just wear out to... it was sorta easy to replace and was easy to find at the local parts store..
  14. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I guess I better check that out. Thanks for the input!
