Key slipped in my hand, now won't start (update...it's alive)
Discussion in 'The Garage' started by BlazerFarm, Jan 31, 2005.
  1. BlazerFarm
    BlazerFarm Texagonian Premium Member
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    This morning I was starting my 1990 K5 when the key slipped in my hand as I was turning the ignition. It was just about to turn over and it died. Now I can't start it at all. I tried for about 15 minutes this morning and about 10 minutes this afternoon. The starter just cranks continuously and it never turns over. Any idea what could have happened? It worked just fine the day before. It seems like it's not getting any fuel or something although I don't know what the key slipping and it shutting off would have done to it. It happened once before about 3 months ago but it started then after about 5 attempts. Not now.
    By the way, where is the fuel pump on the 1990 TBI engines? I'm used to the '70s K5s where the fuel pump is stuck on the side of the block. On my '90 there's a plate where the fuel pump would have been.
    Any help is appreciated. I'm not that familiar with the TBI fueled engines.
    Thanks,
    --Don
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    so its not cranking the engine over at all? if not sounds like the starter drive went out.
  3. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Well, the starter is turning but the engine won't fire. I've tried enough times now that it's starting to drain the battery. The starter did go out about 6 months ago. There's a new one in there now.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    starter solenoid.
  5. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    So would the starter turn with a bad solenoid? I thought the solenoid had to be working to turn the starter. When I replaced the starter 6 months ago it came with the solenoid. Now that doesn't mean that they couldn't have gone bad again.
  6. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    sounds like a fuel pump fuse maybe.. your pump is in the tank. do you hear the pump run when you turn the key to on?
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Take off the Round air cleaner and have someone try to crank it. See if there is fuel squirting in.
  8. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    I just tried it again. I don't hear anything when I turn the key to on before the starter cranks. Is there a fuel pump fuse in the fuse block under the dash?
  9. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    I've got the air cleaner off. I'll have to get someone to come over to check it out while I crank it or vice versa. So you would be able to see fuel going into the throttle body as it cranks if it was working ok?
  10. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    ECM b fuse is the pump fuse, i believe.. someone correct me if thats wrong..
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes you should be able to see the gas coming from the injectors.
  12. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Thanks. I checked the ECM B and the ECM 1 fuses. Unfortunately, both are still good.
  13. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Well, I'm having to look through the hood opening while I turn the key but I don't see any fuel coming out of the injectors. Plus I don't smell gas after I try it out.
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Turn the key to the "on" position and listen for the fuel pump running. It's located in the gas tank. It should run for about 3 seconds, just long enough to build pressure then shut off.
    Since you said this happened right after your hand slipped off the key I'm leaning towards the ignition switch taking a dump. Does anything else not work?
  15. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah that is what i started to think.
    like it gives power to the starter but not ignition or something.
    when your cranking it does the motor spin? (look a the fan)
    are the lights and gauges in the dash comeing on with the key?
    pull all your fuses just to be sure and check them i have found things i dident think were togeather tied in to different things.
    ,aybe check the voltage to the fule pump when you turn the key.
  16. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Sounds like a classic case of the fuel pump solenoid going bad. It is the little relay on the firewall to the passenger side of the distributor. Without it operating there will be hard start condition because then the oil pressure must be high enough to activate the oil pressure switch which keeps the the fuel pump running. It's a set up designed to turn off the fuel if the oil pressure is lost. This relay keeps the fuel pump on during starting. Most trucks with a bad relay may start after 10 seconds of cranking (if the battery and starter are in very good shape) because the oil pressure comes up. I've had trucks that wouldn't start at all however. Slap in a new relay. They are only $8.
    Jeff
  17. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,012
    841
    Pinckney, MI
    I learn something new everyday! :thumb:
  18. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    let us know if it works!
  19. Emmettology 101
    May 9, 2000
    8,126
    FL
    Another couple things it could be is the Disty module or the oil pressure sensor if you're not getting fuel or spark.
  20. BlazerFarm
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Thanks Jeff for the suggestion. I replaced the fuel relay but it still won't turn over. I do hear a pronounced "click" now after I turn off the key so the relay sounds like it's active at least. Any other ideas?
    Thanks,
    --Don
