Key won't turn! Replaced cylinder already?
Discussion in 'The Garage' started by anatomiczero, Jun 14, 2003.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    Key won\'t turn! Replaced cylinder already?
    I've been having trouble getting my key to turn to the start position. Sometimes it won't turn, or i'll have to turn it hard all the way to barely get it to start. Just now I spent 5 mins trying to turn it and now my thumbs are sore.
    So what's the problem if it's not the cylinder? Thanks.
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    Re: Key won\'t turn! Replaced cylinder already?
    long style screw driver, take the key out, put the screw driver between the two ears and crank on it, it'l either break or move thething. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    How worn out is the key? /forums/images/graemlins/grin.gif
  4. anatomiczero
    Jun 26, 2001
    418
    Washington
    brand new since I replaced the cylinder.
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Is the linkage to the actual starter switch, moving freely?it's just a long 1/8" rod, that connect's to the switch.
    It's down low on the column.
  6. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    i bet you have a worn out ignition switch /forums/images/graemlins/laugh.gif.. depending on how much dash you have still installed /forums/images/graemlins/smirk.gif(i have none) the fix is pretty easy...
    take off all related stuff so you can drop the steering column down. on top is the ignition switch. there are some contacts in there and a return spring. mine were burnt out so they wouldn't slide...
    do a search i know someone did a post about how to change it /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  7. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    try turning the wheel while turning the key
  8. anatomiczero
    Jun 26, 2001
    418
    Washington
    Thanks, that worked. I'm going to go buy a new switch. Chilton's says I just need to drop the column, unplug the old and plug in the new one.
