Keyless entry used as a kill switch?
Discussion in 'The Garage' started by 88K5Jimmy, Mar 1, 2007.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Is there anyway to rig up a keyless entry system like the one pictured below to be used as a kill switch? My thoughts...when you "unlock the doors" it will connect or provide power to an ignition wire/fuel pump wire thus completing the circuit and enabling the truck to start. However, when you "lock the doors" it disconnects or halts power to an ignition wire/fuel pump wire. Would a seperate relay be needed in order to make that work? I haven't yet dug into the instructions on the keyless entry to see if it's even possible..but it sounds good in theory. That way you wouldn't have a kill switch available in the truck for the thief to see/find. I am thinking about doing something like this for the summer use...no doors and soft top because it will be easy to get into and access. Thoughts?
  2. K-5 Bomber
    K-5 Bomber 1/2 ton status
    Aug 20, 2006
    108
    Northeast California
    Sounds like a great idea! I would be able to wire the whole works though one system, but even if you needed a secondary kit, it would still be worth it. I've been thinking about that myself. I may be going to Galt for a while this summer, but I still want to be able to go with my safari top. Let me know how this works out.
  3. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    On the Viper alarms I install most have a built in starter kill relay, basically you would put a relay inline with your starter wire, I can look for a diagram at work and post it if I can find one.
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I would love this for my truck let me know how it goes.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    My recallection is that most of those systems are designed to operate a solenoid. They aren't a switch, their output is a reversable polarity momentary signal. You could use a power door lock solenoid to operate a switch in whatever circuit you desire.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    sounds sweet. keep us posted
  7. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    I have done that. Most of those systems have a starter disable feature when the doors are locked. That usually works by supplying ground to a relay when the doors are locked. They are designed to ground a relay and open the starter solenoid wire circuit so the vehicle cannot be started. However, my MSD 6AL has a feature where if you ground the white wire, it shuts off the spark. So I simply hooked up the wire thats grounded from the keyless entry to the white wire on the MSD, bingo. Now when the doors are locked the engine won't start. And the really funny part is (because you can mess with people) if the vehicle is running and you hit the button it locks the doors and shuts the engine off. However, I take no responsibility if someone accidentally shuts off their engine when going down the road and has problems because of it. If you don't have an MSD, you can use the relay and either disable the starter with the doors locked, or put a relay in the coil power wire (battery + on an HEI) and it will shut the spark off. You can buy a 30A relay for $3 at many auto parts stores, just make sure you hook it up to the normally closed side of the relay. There will be a diagram on the relay. Hope this helps.:wink1:
  8. jfaulk
    jfaulk Registered Member
    Dec 3, 2006
    60
    NC
    great idea. let us know how it works out for you. also, this would be a good opportunity for a tech write up. I'm interested in this idea myself.
  9. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Wow I didn't think there was going to be this much interest...I figured it would be more like "you idiot that's never gonna work" lol I will have to look at the instructions and see if it's even possible with that system...it's a factory GM unit as you can tell but it's also pretty old, so hopefully I will be able to use it...we shall see
  10. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I'm interested as well, likely in the starter kill option. No ignition on a diesel...
  11. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    No there isn't, but with a latching relay you could easily turn the pump solenoid circuit on and off.
    Thinking about it, could do the same thing with the crank circuit on a gasser.
