Keys?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cmoe, Sep 24, 2001.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Well I want to get a key made for my electric rear window on my K-5......The guy at the action wants to know what is the code on the side of the keys..... My ignition is a "E", The door lock is a "B", does anyone have the code on the side of the stock key for their electric rear window....So he can bring those Master keys so we can see if any will work.....It will be a big help....
    C'moe
    Kill Roy was here!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Mine has a "B" code on it
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Doesn't the door key work the rear window? Mine does.... So they would be the same key... if your door key is a B, then that'd make yer window the same right?
    GOD BLESS AMERICA!!!
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    same thing with the Burb, the door key works the rear window.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  5. Grim-Reaper
    7,385
    Atlanta
    Depends on the year. I know that at least through 79 (because it is this way on my 79) used the old style (60's) Briggs &amp; Straton ignition key with the small octogon head. Not sure what year they went to using the door key. My 70 Burb uses the same square ig key for the doors also.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    My door locks have been changed out when I bought the Body......No keys came with it....Thanks.......I need to go to my sorage to see if I still have those locks....
    C'moe
    Kill Roy was here!
  7. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    my gate window key is code H. I am not sure but i believe the switch was replaced so i have a different door and window key.
