Kick down cable operation....
Discussion in 'The Garage' started by AkMudr, Feb 11, 2005.
  1. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Not a common everyday question but here's my dumb question for the month, lol.
    Someone explain how the kickdown cable works in conjuntion with the throttle cable..I.E. Is it the throttle cable that activate the kickdown? or vice versa?
    Also..when the kickdown operates...is it pulling or pushing against the stud? I have 1 stud ont he lower portion of the linkage, not a nipple but more of a stud with a groove around it...It only pulls back towards the firewall, no forward motion.
    I need top figure out if the availabkle stud on my Qjet is where I hook the cable or not. I should go take a picture of it so ya'll can verify it.
    P.S. Asking becuas emy truck came iwht a th400, and I'm swapping in a th350.
  2. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    cable is for tranny to know how much load is on tranny. it works with the modulator. it is a pull style, needs to go to fert as throttle is used. and at w.o.t. the cable needs to have just a tiny bit of play from beeing fully extended . o.k. hope this helped you.
  3. AkMudr
    Dec 30, 2004
    917
    Alaska
    So the KDcables' linkage works seperate from the throttle cable linkage? One doesnt activate the other?
  4. sweetk30
    Nov 1, 2004
    25,552
    546
    the throttle is on top of arm and kick down is on bottom . about the same movement for both in respect to direction.
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    I'll go out and snap a pic so you can tell meif its set-up right.
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Looking at your Q-jet throttle shaft from the side......
    Your throttle cable is mounted in the top hole and when you depress the gas pedal it pulls the top in towards the firewall and turns the throttle shaft clockwise.
    The detent cable is on the bottom hole and is pulled away from the firewall in the same clockwise motion.
    Your detent has a mounting bracket at the back of the driver's side manifold and then snakes down to your transmission.
