Kick Panel clearance
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 67lemanster, Dec 9, 2005.
  1. 67lemanster
    67lemanster Registered Member
    Sep 20, 2005
    18
    dallas, tz
    i am wanting to put some component speakers in the front of my blazer. i plan i putting the tweeters in the a/c vents on the side of the dash. i was wanting to put the 6.5" woofers in the kick panels. this would require me cutting a 6" round hole metal panels, which i am ok with(i have done on my lemans and my camaro). how much clearance is back there? i only need about 2" depth max. any other things to look out for? thanks
  2. 67lemanster
    Sep 20, 2005
    18
    dallas, tz
    it will work but there is a verticle support between the outside kick panel and the inside panel. oooops. the verticle brace is right smack in the middle of the hole. back to the drawing board.
  3. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    i saw some plastic pannels on e-bay once. they angled the speaker out. this gave me the idea to make my own outa fiberglass. have not done it yet though. the pannel held a 6.5 " speaker. might want to see if you could find thoes. i dont think it will mess with anythign else, only question is the e brake pedal.
  4. huntinfool79
    huntinfool79 Registered Member
    Jan 10, 2003
    12
    Helendale, CA
    kick panels
    LMC has kick panels designed for speakers. I think they will hold a 6 inch and can probably be cut to hold bigger.
  5. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Ever thought about doing something on the floor...?
  6. vtblazer
    Sep 30, 2003
    2,471
    Central VT
  7. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Images above "borrowed" from Greg72's picture album.
  8. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    I am pretty sure that water runs behind the kickpanel when it rains (it flows down from the cowl. If you cut a hole and put a speaker there, the back of the speaker will get wet.
  9. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    JakeSlim made some really slick kick panels for his 69. Even posted pics not too long ago. Hand laid glass with the speakers angled out.
