Kickdown linkage?
Discussion in 'The Garage' started by 82_k5, Feb 28, 2006.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I bought a q-jet carb for my 82 jimmy but it doesn't have the linkage thing to connect the kickdown cable from my 700r4. It has the hole on the linkage where the connector might go. Is there somewhere I can buy that little connector? The one on my old carb looks like it's pressed in so that won't work. Any help would be greatly appreciated. Thanks.
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  3. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    You could contact the place you bought the Q-jet from and tell them you need a 700R4 TV cable bracket for your carb.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A small bolt the right length to clear all the linkage around it , with 2 washers , and a locknut with the plastic at the end . Leave it a little loose so it doesn't bind .
    Won't make taking it off as easy as stock though .
