Killer front driveshaft [hoop it?]- NOW WITH PICS
Discussion in 'The Garage' started by fatbob, Sep 10, 2006.
  1. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    My front driveshaft came apart at the CV joint and killed my tranny today:mad: It not only smashed the pan, but bashed in the side of the transmission too, so I gotta get a new tranny. Anyone else have this happen?:ears: I'm thinking if this is a somewhat common problem, then maybe I should fab up a driveshaft hoop, but if it's just a bit of bad luck, then just replace the tranny a move on.:dunno:
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Buddy of mine basicly took a length of strap like an inch wide maybe a foot long, made a hoop, ran a bolt through the ends and bolted it to his frame. Worked great the many times he has blown a front shaft. Seems like a simple easy mod.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Wow!!! Got any pics of the damage, brother?
  4. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    does this happen to alot of people? should I hook up one of these things too?
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    common??...
    It does not happen often,but is entirely possible!...I have witnessed similar destruction while plowing parking lots..a guy with a K30 had a front spring shear its center bolt due to loose u-bolts one snowy day....the front axle moved back about 6" when the tire hit a cement "stop" (the thing your tires hit when you park so you wont go too far and hit a wall,etc)...
    The front driveshaft pushed the transfer case back hard enough to crack the adapter to the tranny,and it tore out the part of the tranny where the 4 bolts held the T-case to it (he was running a TH350/NP205 at the time)..it also folded the driveshaft up like a pretzel,bent the rear shaft too--and the transfer case just about dropped to the pavement!:eek1: ---needless to say,his plowing was brought to a complete and sudden stop!...to add to his woes,one of the leaves in the front spring speared his tires sidewall..:doah:
    ...the T-case survived,but he had to get another tranny ,adapter,driveshaft,and fix the spring..he parked it until spring and used another truck,rather than fix it in the cold weather..I think a loop isn't a bad idea..even a failed u-joint can let a driveshaft flail around, and do NASTY damage to anything in its path!..I've seen floors torn out of cars that lost a rear U joint during a burnout!..:crazy:
  6. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    oh jeez..... So is it just a loop? or like a length or strapping, with a "circle" in the center? If I do it, I want to do it right.
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    what a horrible friggin day.
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    think a driveshaft has much of a chance bashin in an sm465?
    Ive also seen a guys driveshaft push back on the transfercase, the thing was too long and when he flexed it the driveshaft bottomed out and pushed back, just broke the adapter though.
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I'm sure someone has broken a 465, but I would think it would have a pretty darn good chance of surviving.
  10. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    Sorry Paul
    nonpaying members cant post pics
    but it cracked the case from the side all the way over the top in the back.:doah:
  11. Can Can
    15,552
    136
    I sent you an email, brother.:thumb:
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    so pay up sucka! we wanna see the pics! :haha:
  13. Can Can
    15,552
    136
    I have the pics if anyone wants to host them for me. Ugly damage, that's for sure...:yikes:
  14. Seafarer76
    Seafarer76 1/2 ton status Premium Member
    Apr 10, 2006
    340
    Las Cruces, NM
    I can host em.
  15. Can Can
    15,552
    136
    PM me your email addy, brother, and I'll send them to you.
  16. Seafarer76
    Apr 10, 2006
    340
    Las Cruces, NM
    Pics
    Here are the pics of the carnage...:eek1::eek1:
  17. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Holy busted tranny Canman:D . That thing is Fo(ked up:doah: .
    Ira
  18. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    daaaaaaaaaaaaaaaaaaang
  19. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    Thanks for hosting the pics Seafarer76.:thumb:
    Now you can see why I'm worried about this happening again,:eek1: and thinking about a hoop.
    I'm starting to feel like I'm in the special olympics. I not winning the race, but I dont have enough sense to give up either.:crazy:
  20. sandawgk5
    Oct 28, 2003
    6,881
    It looks like if you did make a hoop that mounted to the frame rail it would keep the shaft away from the tranny and tcase and it would be fine. Also if it is mounted back by the CV it would provide the most protection for the tranny and yet not impact the travel of the shaft during flex.
    Ira
