Killer PDF file I found on U-Joints
Discussion in 'The Garage' started by Muddytazz, Sep 22, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  3. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Yep a cool link. Would I be wrong, but when I replace u-joints I don't buy real expensive ones. I don't look for cheap ones either, but if anything is too break I want it to be my ujoint. Am I thinking right? Or am I just nuts. :D
  4. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    Yea ... U joints should break first. I stay away from the costly- strong ones. Best results are with the Dana's from NAPA.
  5. Brocky
    May 22, 2005
    1,170
    :doah: Jinxed myself, Ujoint just made some noise when I went to the store. It's in the rear shaft. Off to Napa I go, might as well pick up some calipers and pads for the front while I am there. I do most of my shopping there. Sometimes Canadian Tire but mostly Napa.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Unless it starts taking out other stuff when it breaks. Like when a front axle joint breaks, then binds up the ears on the stub shaft & snaps them, which causes them to ride on the ball-joint and cut it to pieces. So now you are sitting on the side of the mountain, with your steering knuckle laying on the ground, extolling the virtues of you cheep u-joint acting as "fuse". :haha:
  7. Brocky
    May 22, 2005
    1,170
    Ya I agree with you bigjbear. I wouldn't want to go thru that again. I bought expensive ujoints for my stub axles. But for my driveshafts I like to keep it simple. But if they start causing breakage else where I will buy better ones. Only yesterday at our 4 wheel drive show we found out alot about ujoints. Side axles busting apart and driveshafts twisting off all day long. This pic is my buddy Joes truck. He was in a tug of war with another pickup and his started hopping. His rear yoke snapped off and his pinion was majorly messed up. I never let my k5 hop too much. Only leads to breakage.
