king pin slop
Discussion in 'The Garage' started by highrider_44s, Mar 30, 2004.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    the king pin on my d60 moves up and down only. it seems tight everother direction. does it need to be shimmed under the spring /forums/images/graemlins/dunno.gif or does it need a complet rebuild I know there prone to ware. i put the crossover steering in and moved the cap from the otherside over could this be the problem. /forums/images/graemlins/confused.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    put a new plastic bushing and spring in it thats what fixed mine /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    is plastic bushing in the top /forums/images/graemlins/dunno.gif
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    king pin rebuild kit $49.99 a side. You can get just the new nylon cones, springs, kingpin caps for like $15 a side.
    Chris
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    cones thats a better word for them then bushings lol /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    does the bottom bearings fail often with 40"s
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Everything fails often with 40s. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Remember, NO pickup truck axle was designed for those size tires from the factory. EVERYTHING wears faster with big tires.
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I had the same problem. I replaced everything last weekend (while you are there might as well -> thanx harley) My passenger side poly cone came out in 2 pieces, the springs were a little shorter than the new ones. I am not so sure the bearings and races needed to be done but I figure the vertical movement is hell on the race (probably warps the bearing cage also). The botoms don't fail as often but they do fail. I got mine from 4wdfactory real nice guy (answered the phone on a sunday and took my order just cause he was there).
