King pin studs
Discussion in 'The Garage' started by NoSmog73, Mar 13, 2005.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    How what is the best way to put the kinging pin cap studs in since there is no head like a bolt..Just tighten them up with a pair of vice grips around the smooth area of the stud good and tight with some lock tight...
    Kinda dumb ??? but making sure there isnt something I might miss
  2. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    go to sears and get a stud install/removale tool less than 20 buck i think. it will help you big time. it uses a 1/2 drive and is round with off set cam in it to bite the stud flat spot. and clean the hole and use locktite for sure.
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    or take two nuts, lock them together on the stud and screw it on in....not the best but it does work:)
  4. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Thanks Guys
