King Pins For Dana 60
Discussion in 'The Garage' started by 78Blazer, Sep 17, 2002.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I called around today trying to find kingpins for my 60 and no one has them. Where am I supposed to get these things and how much do they run?
    /forums/images/icons/blush.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    exactly what part are you after?
    the lower 'kingpin' is a tapered bearing and race
    the upper 'kingpin' is a machined tapered cone with a matching ?nylon? bushing that is preloaded with a spring similar to a valve spring.
    there are a couple of seals to retain grease as well,
    gaskets to seal the covers and steering arm,
    a ?post? on the bottom that retains the tapered bearing.
    let me see if I can link to the dana expert page
    I circled around for a while but didnt fall on the exploded image that I know is there ???
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What do you put in for model # of the Dana 60? I tried 60, model 60, dana 60, etc. and it would not show as a valid model for a parts list. I must be missing something obvious.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Call these guys. They had stuff for my 60 and the price for the parts wasnt bad.
    Boyce
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    easier to search by make/model but I didnt find the diagram so...
    I think the D60 is now the m248 or something like that in Dana-speak
    I have the diagram in Word format
  6. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Randy's Ring & Pinion has the upper kingpin and nylon bushing as part of a D60 rebuild kit.
    Prices are reasonable too....
  7. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I just replaced everything on the used 1985 K30 Dana 60 I have, including upper and lower king pins. I went straight to the local GM dealership and found/bought everything there. I don't know if that was more expensive than other places or not (maybe it was), but they were able to get everything I needed within a 24 hour period, which made it worthwhile to me. I can't remember exact prices on everything, but if you really need part numbers and prices, I could compile that tonight at home, and enter it here tomorrow (I don't have a computer at home).
    One thing I didn't buy from GM was a lower kingpin kit, I bought an aftermarket one that was slightly more expensive, but it featured a 1.5 degree adjustability in camber.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  9. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Need part #'s for the lower kingpins , the one that bolts to the bottom with 4 bolts , and goes up into the bearing , need #'s asap!!!! Info much needed and appreciated!! Thanks ........CC
  10. CCRider
    Jul 8, 2001
    314
    Found the DANA # for the part , Need GM part # please!!!! Dana part # is 37299 CAP-KING PIN BEARING LOWER, need these new if anybody has these or knows where to get them , I could if I had the GM #!!! Thanks ....CC
  11. madmike
    Jan 23, 2002
    496
    ohio
    I didn't have any part numbers for anything, just a crusty 1985 Chevy Dana 60 axle. I just went to the dealership, told them what I had, what I wanted, and they ordered it. Got everything I needed in one day. As for the lower king pins, I did not go GM. I was in a parts store one day trying to get the lower king pin kits cheaper, and they had a kit that was similar to the GM offering, a little more expensive, but it had a 1.5 degree adjustability of camber built into it. I'm not sure if it was a good idea or not, but I'm going to try it.
    I figure if I wheel the wee out of it, or maybe bend an axle tube (slightly) or whack the axle into something really hard, or if I get the dreaded death wobble, maybe that extra 1.5 degrees of adjustability may come in handy. I figure for roughly the same price, why not get a little extra? I'm new at the whole Dana 60 thing, so this is not the voice of experience, yet. If you want the part number of what I got, I'd gladly give it to you.
  12. CCRider
    Jul 8, 2001
    314
    Sounds interesting!!! What's the number/manufacturer , and where did you get it!! ..........CC
  13. madmike
    Jan 23, 2002
    496
    ohio
    CC, I called the H&W auto parts store that I bought the kit from, and they remembered me. The part is a Moog (or Federated) brand, the part number is K992, and the price was 117.67 for one kit, for one side. (That one really hurt me behind!) Good luck!
  14. CCRider
    Jul 8, 2001
    314
    Hey , I found them on the net for 83$ each side , are they good quality? do they look like they will hold up to extreme bashing on the rocks? I saw a picture in my moog catalog , and was wondering if they are worth the money? Does it have an area for the lower seal to ride on? Greasable? Sorry to ask so many Q's , but I've got to know if it's worth 170+ to get these over the stock non adjustable ones!!! Thanks ............CC
  15. CCRider
    Jul 8, 2001
    314
  16. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    DAN3-82-871 is the 35 spline outer stub shaft.
    Warn 38786 is the 35 spline locking hubs.
    Knuckle Rebuild Parts
    kingpin spicer part# 37302
    lower bearing kit part# 706395x (includes bearing ,race,dust shield and seal for upper king pin)
    upper king pin bushing part# 41886
    upper seal kit part# 620058 (really you will not need to buy this seal if you buy the lower bearing kit because it is in it)
    upper bearing gasket part# 37307
    Bearings
    inner seal Nat 415960 - 2.75x3.876x0.375
    inner bearing Tim 387A
    inner race Tim 382A
    outer bearing Tim LM104949
    outer race Tim LM104911
    outer axle 35 spline part# 3-82-871
    u joint greaseable Spicer spl55-4x
    34643 SLINGER - PINION BEARING INNER
    706046X INNER PINION BEARING KIT
    706375X KIT - DIFF & PINION ADJ SHIM
    30982 BAFFLE - PINION BEARING
    706359X KIT - PINION BRG ADJ SHIM
    706045X OUTER PINION BEARING KIT
    42737 THRUSTWASHER - BEARING
    42449 SEAL - PINION
    2-4-3801X END YOKE ASSEMBLY (INC 10)
    34592 SLINGER - END YOKE
    30275 WASHER - PINION NUT
    30271 NUT - PINION
    34822 BOLT - CARRIER COVER (QTY 10
    34687 GASKET - CARRIER COVER
    48632-1 BOLT - DIFFERENTIAL BEARING CA
    706047X DIFFERENTIAL BEARING KIT
    706378X KIT - DIFF BRG ADJ SHIM
    30266 BOLT - DRIVE GEAR (QTY 12)
    34367 PINION
    34729 THRUST WASHER
    34730 THRUST WASHER
    44810 LOCK - DIFFERENTIAL SHAFT
    30263 DIFF SHAFT
    36487 SEAL & GUIDE TUBE
    706395X KIT - KING PIN PARTS
    620058 SEAL - KING PIN - UPPER
    37305 RETAINER - GREASE
    706150X KIT - BEARING - KING PIN - L
    41777 SEAL - OIL
    31026-1 SCREW - STOP
    500381-3 NUT - HEX SLOTTED
    500381-3 .375-24 HEX NUT
    500175-1 FITTING - LUBRICATION
    30875 NUT - HEX TAPERED
    38139 ARM - STEERING (LH ONLY)
    620132 CAP - KING PIN - UPPER (RH ONL
    37307 GASKET - KING PIN CAP
    37300 SPRING - PRESSURE
    620180 GEAR
    41886 BUSHING - KING PIN
    37302 PIN - KING
    72837X KIT - RIGHT KNUCKLE ASSY (49,
    72838X KIT - LEFT KNUCKLE ASSY (50, 5
    41893 RIGHT KNUCKLE
    41894 LEFT KNUCKLE
    37879 BOLT - HEX
    37299 CAP - KING PIN BEARING LOWER
    500357-13 LOCKWASHER (KING PIN CAP - LOW
    500412-13 BOLT - HEX (KING PIN CAP - LOW
    37308 SLINGER
    700014 KIT - SPINDLE SEAL & BEARING
    37311 SEAL - OIL
    37312 SPACER - WHEEL BEARING SPINDLE
    620062 SEAL - NEEDLE BEARING
    620063 NEEDLE BEARING - SPINDLE
    36880 NUT - BRAKE MOUNTING
    48816 SEAL - GREASE
    706411X INNER WHEEL BEARING
    706074X INNER WHEEL BEARING KIT
    35830 GEAR, TRAC-LOK
    707083X KIT - DIFF PLATE & DISC (T/L)
    40835 CLIP - DIFF CLUTCH RETAINER
  17. madmike
    Jan 23, 2002
    496
    ohio
    Sorry it took awhile to get back to you (I don't have a computer at home). It's a Moog part, so there is no question its a quality part, the bearing was a Timken, so question about quality there either. They are fully greasable, like factory. I have installed these parts only a couple of weeks ago, but my truck is still not up and running, so I cannot tell you yet how they function, but it should be fine.
  18. CCRider
    Jul 8, 2001
    314
    Thanks guys , I think the stock lower kingpin is dana # 37299 CAP-KING PIN BEARING LOWER , But I think I'll try the adjustable ones....... A little extra camber.. HMMMM !! thanks again, you guys came through!!! .........CC
  19. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    What is the advantage of extra camber? I need to rebuilt my kingpins as well since my lowers are kinda messed up.
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
