king pins
Discussion in 'The Garage' started by dheavychevy38, Sep 23, 2004.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i know it's been covered but heres the thing i put on the raised steering block and now it's loose so what did i screw up? /forums/images/graemlins/whistling.gif
    is there a good tech right up on how to service them some where new to the 1 ton world but nothin but problems so far /forums/images/graemlins/angryfire.gif
    just when you think you are done /forums/images/graemlins/screwy.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    was the steering block spring spacer thing loose as a dick in a shirt sleeve?
    the one I had custom made was a nice tight fit and the commercially available ones look like they are a 1/2" different bore to spacer
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    yep it's a superlift block the kingpins were tight until i tried that dumb block now i can't get it to go back to no slop haven't tried it again with out the block though thats tomorrow job
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    any ideas thats all i have left to be able to play i am getting pissed at this stupid thing i know it's got to be some thing simple /forums/images/graemlins/dunno.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    -get a bushing made to take up the slop bronze perhaps
    -get crossover steering
    -use a dodge steering arm retapered for chev draglink on top
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    weld a plug into the block that would put the spring at the same hieght as the stock arm
    replacing the stupid spacer altogether
    then drill a grease fitting hole into the front, side , or back whichever is easiest to get a greasegun on to
    you could get creative with that idea and make a built in threaded adjustable kingpin spring preloader
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    cross over money got spent else wear time to save again
    the plate to stop the spring idea or make a new block with the stud holes and the hole for the spring now i am thinking thanks for the help
    the dodge arm will fit just have to change the taper or can you just get a different draglink end /forums/images/graemlins/waytogo.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dodge arm factory has the tierod enter underneath IIRC
    you retaper it from the top with a chev size and it is like a 2 or 3" lift
    BUT it requires a shorter draglink so some grinding on the draglink ends is required
