Kingpin Retaining Cap question...
Discussion in 'The Garage' started by ARAMP1, Dec 31, 2005.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Got a quick question. I was starting to get a little bit of death wobble this week. The whole front end is really tight, so I decided to shim the kingpin spring. Anyway, the left side is really stout with studs and conical nuts and then I got to the right side and it is really thin and bolted in. I know the left side is really heavy since the steering tie rod is connected to it. Is this right? Seems like the right side should be thicker and have studs with conical nuts.
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    That is the way they are...
    Rene
  3. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Cool. Thanks!
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    the studs and conical nuts are to keep the arms from moving side to side because of the hole being larger then the bolt when forces are applied to it. because the opposite side does not have a steering arm (and the forces that reuslt because of it) it does not need anything of the sort
