Knock right after motor starts
Discussion in 'The Garage' started by mountainexplorer, Dec 20, 2002.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I think I have a motor that is going out. When I start it, after 3 seconds from when it fires, it makes a knocking noise from the bottom end. The knocking lasts about 2-4 seconds, then quits. I can run it for however long I need to, and it won't knock at all. It only does it right after it starts, especially when it's cold.
    It's an old motor, been sitting most of the last 8 years. Has new oil and everything from when I first started driving it again a month ago.
    Bearings going out maybe?
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    is it an auto or standard, my flexplate made a similar noise when it cracked around the bolt holes.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Its a manual. It's definitely a motor noise. Sounds like it quits right after the oil pressure comes up.
  4. Grim-Reaper
    7,385
    Atlanta
    Loose that POS Fram oil filter and use a AC filter or a Puroil 1. The drain back valve in your fitler is't working. The oil is draining back though the filter into the pan.
  5. Md mudder
    Md mudder 1/2 ton status
    Sep 29, 2000
    139
    I wouldn't worry about it much it will probably run for years like that. My wifes 97 suburban does it.
  6. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i would make shure your drain back valve is working, if it is then it mught be crank bearings.
