Knock Sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Jul 6, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Where is it located? I used my code scanner and the results say to check the cables around the knock sensor or replace it all together.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</A>
  2. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    on the pass side in front of the starter but some have two one on each side at about the same spot
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In the water drain holes, above the middle of the oil pan, in the side of the block.
    Tim
  4. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Tap on the top of the block, and it should retard the distibuter timing if it it still good. If not, replace it with a diesel! GOPHERKILLER
