Knocking from brake pads on D60
Discussion in 'The Garage' started by Fubeca, May 6, 2003.
  1. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    When I first installed my D60, I put new pads, calipers, rotors, and bearings in it. Now I get a kind of clacky knocking noise from the front sometimes. It seems to be the pads shifting forward and backward against the supports and making a clack. Have any of you had this happen? Any ideas on how to either quiet it down or fix it?
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Did you make sure to reinstall the little clips that go on the bottom of the inner pads when you installed the new ones?
  3. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    There were no clips on any of the pads when I took them off the old truck. Any ideas where I could get them?
  4. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Nevermind, I found them at the local parts store, I'll see if that solves my probs.
    Thanks Waxer
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The clips help keep a little tension on the pads but will not keep them from making noise. The shoes have tabs on them that can be bent in to make them fit tighter and not rattle or clunk.
  6. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Okay, I got the clips but haven't pulled the wheels off. Should there be a clip on each end of the two inner pads -- 4 total? Or just one per pad. Also, does the spring tab thing stick toward the truck or toward the wheel (or is there only one way it will go and I'll know the answer when I pull the caliper off)? /forums/images/graemlins/confused.gif
  7. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    there is also a small slab of metal in the piece that actually holds on the caliper if its gone theres your problem.
  8. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    I think if I was missing that piece I'd be having more problems than I am /forums/images/graemlins/rotfl.gif
  9. 83PJW
    Aug 18, 2002
    160
    leavenworth, ks
    not necessarily im talking about a smaller piece between the actual piece that holds it on and the caliper. if its gone the caliper will not fall out it will vibrate. thank you.
  10. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Oh, I get it -- the spring thingy is in there on both sides.
