knocking out the old bearing races
Discussion in 'The Garage' started by dirtynails, Dec 18, 2006.
  1. dirtynails
    dirtynails Registered Member
    Aug 28, 2005
    96
    Gosport, Indiana
    So what's the trick to knocking out the old inner and outer wheel bearing races? Do you just bang on them with a screw driver or is there a smarter way? And what about installing the new races? Any special tool?
  2. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    special tools..
    I have a bearing/bushing driver and removal tool,but rarely use it!..I just use a brass punch and a hammer 90% of the time..sockets work too,if you find one fits close enough..after installing new races,be sure to torque the wheel bearing nuts fairly tight,while spinning the wheel,to ensure they "seat" fully--then adjust them in the usual way..:crazy:
  3. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    as far a "special" tool, you could use a punch and drive out the old and drive in the new. or use the old races to drive on the new races, or get set of bearing drivers (a whole buncha (~60)round disk 1/2 thick and OD.s from about .5 to 4.5) I use a 1 x 12 inch copper rod to drive out old races and use the old races and rod to drive in the new ones.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    these guys got it covered, a long punch is nice to knock them out and a bearing race installation tool is good to put them in, if you dont have access, a piece of bronze or brass cut into a drift punch will work (softer metal than the race)
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    If the race is all that is left you can weld on the inside of the race, run a bead all the way around and it will fall out. By welding it you are making it shrink, thus being smaller and falling out.
  6. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,202
    So Cal.
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You just couldn't resist the temptation to pimp your goods, could you, Robert....... :rotfl: :rotfl: :waytogo:
  8. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    On the not-quite press fit races, yeah drift them out with just about anything, but here's a trick for installing the new ones. Sorry Robert, built, not bought.
    If you have any disc type cutter, or plasma(wow), cut through the old race, inner or outer as the case may be. Then it becomes a spring instead of a fixed diameter hoop. Butt your new tool against the new race and tap around and around, just like you used to do with a screwdriver and bugger-up the race, only now the new race is protected. You can tell by the sound when the new race is fully seated. Then just pop-out the "tool" (old cut race).:D
  9. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    Also, make sure you throw your races/seals in the freezer for an hour or two before installing... they shrink just enough to make it easy
  10. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    And stuck the hub in the oven to make it warm so it expands! Although, not the oven you eat out of:doah:
  11. rdn2blazer
    Jun 9, 2004
    16,496
    1,202
    So Cal.
    YOU GOT IT BABY!!!!!!!!!!:grin: :grin: :grin: :grin: :grin: take a look at my I trader and you will see the light my friend. everybody could use one of these, even the womens out there from what jek says LOL!! :haha:
  12. rdn2blazer
    Jun 9, 2004
    16,496
    1,202
    So Cal.
    thats how my tool came to be, I built it for me, now I just share the love with my fellow ck5ers :D
