Knocking Sound near water pump???
Discussion in 'The Garage' started by erin3183, Feb 13, 2004.
  1. erin3183
    erin3183 Registered Member
    Feb 13, 2004
    8
    Hi, I have an '89 chevy 4x4 with a 305. I wanted to know what might be causing an irregular(no pattern to this knock, totally random) knock near the water pump. I only hear it at idle and when it knocks it also causes the belt tensioner to jerk. This problem just started after installing a new Holley 670cfm TBI. Any help would be greatly appreciated
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    could be the bearing in the tensioner pulley..... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  3. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    maybe water pump?
  4. erin3183
    Feb 13, 2004
    8
    Has anyone heard of a water pump making a knocking sound. I thought that they usually just start to get leaky when they're going bad
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You have a bearing going bad on one of your accessories. When the bearing freezes up it stops the pulley causing the belt to pull tight and that will jerk on your belt tensioner. The knocking sound is the belt tensioner as it gets jerked from a stalled bearing. It could be the alternator, water pump, p/s pump or idlers. Just take the belt off and spin each accessory by hand individually to see if you can tell which one it is.
  6. erin3183
    Feb 13, 2004
    8
    Thanks, I'll give that a try and hopefully narrow it down.
  7. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    This ain't likely the problem, but keep it in mind.
    I changed a tensioner on a Dodge van last month that was jumping. At first I thought something was freezing up, but the spring tensioner was weak - it was 4 months old and put on at the dealer for $275 parts and labor.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    OUCH!!! I knew there was a very good reason to still fix my own rigs! /forums/images/graemlins/thumb.gif
  9. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Maybe, your flexplate is cracked and the bolts are tapping against the inspection cover. It is very hard to determin where sound is actually coming from and will make your belts bounce.
  10. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    This may be out of the ball park but did this engine evr have a mechanical fuel pump on it, for instance before the TBI was put on? If so did you take the fuel pump push rod out?
    John
  11. erin3183
    Feb 13, 2004
    8
    I figured out what the problem was once the alternator stopped charging. The rear bearing was no longer present(completely gone) when I removed the alternator to install the new one. Funny how I'm listening with my face right next to the alternator but the sounds doesn't seem to come from it, though with the new one installed, all is good. Thanks for all the input and good luck.
  12. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Cool, glad you got that sorted out. If you think it's hard tracing down a knocking part on a gasser, you should try it on a 6.2L diesel /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/grin.gif
  13. erin3183
    Feb 13, 2004
    8
    Yeah, I bet...
