know anything about ford rear ends?
Discussion in 'The Garage' started by lowharley, Jul 7, 2004.
  1. lowharley
    lowharley Registered Member
    Feb 18, 2003
    20
    Anybody know what front and rear end comes in a 1984 Ford F250 4wd diesel?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    front will be a TTB suspension so forget that real quick. Its like the F150s front setup where it has 2 seperate pieces, whatever its crap and won't fit anything but an F250. Rear will either be a Dana 60 or a Sterling 9.25 either one is a good axle but I'd say its a Dana 60.
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Our 80's ford f-250 (gas) has IFS up front, and a dana 60 SF out back.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    TTB is fords model of IFS, Twin Traction Beam IIRC. A guy I use to go wheeling with had one and we called the Egg Beaters, nothing like aligning the POS every 3 months.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ooh okay. Thanks for the correction /forums/images/graemlins/bow.gif
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The front TTB axle should be a Dana 50 ( VERY similar in strength to a 44 ) but they have hubs and brakes of a Dana 60 .
    The rear should not be a Sterling 10.25 ( they came in service around 1985/1986 or so ) but a Dana axle ( check the B.O.M. to be sure ) . If the rear axle is a Dana 60 it just might be a factory rear 35 spline set up -so check it out .
    HTH , Tom
    Note : Ford , for some reason , used some strange axle set ups in the mid eighty's so becareful - some F-250's came with S/F C-clip rear 60's and small hub 44's up front .
    If you take some good pictures of the chunks and hubs it will be fairly easy to see what it has .
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    HD or LD f250
    Light duty has semifloating Sterling rear and a D44 TTB
    Heavy duty has full floating Sterling rear and a d50 TTB
    IIRC
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Supercab diesel should be D50TTB and Dana 70FF. (My buddy's stock '85 F250SC diesel was this way.)
    Regular cab is likely a D44TTB and D61SF unless its the high (8000+lb) GVW.
    No Sterling 10.5" until '85 at the earliest.
