Know What I Was Just Thinking?
Discussion in 'The Lounge' started by Resurrection_Joe, Sep 20, 2006.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Unicorn Sex
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    'Spose I could find some......
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I've never had sex with a unicorn.
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I have several questions about unicorn sex...
    -Does the female unicorn have a horn?
    -Does the male unicorn use his horn as a sex toy?
    -If said female unicorn was flexible enough and did indeed have a horn, would there be any need for the male unicorn?
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I imgaine unicorn lesbianism would be rampant
  8. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Why are you thinking about Unicorn sex? Not that I am curious, it's just others might want to know.:rolleyes:
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Thats like asking why the sky is blue... its rj, just go with it!
  10. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    UH... Why the skateboard??? Isn't it risky enough having sex with a dagger growing out of your head. Why would you want to make it more dangerous by doing in on a rolling platform?
    I suppose this could be EXTREME UNICORN SEX, next on FOX
  11. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    What would they call it??..
    If two ghey unicorns have sex..is it called "Unicorn-holing"???.. :confused:
    :thinking: :shocked:
  12. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    The gay unicorn subculture is pretty big
  13. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    And all this time I was led to believe Unicorns were so innocent and pure.
  14. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Sensors: TOL TECH Operation Procedure 35-AT445 w/ Subclavian SensD5CG over 14v INXD R2. I/A I/O XRS Feed w/ 4.6mm Lead and Farcian Halcind R/N bevel.
    Primary Servos: OBI 88.2 and OBI 88.5 at 180psi on a GLASTEN EOH Triple Redundant HC Frame. SiSmAT From Function Analyzer under a .005mm tolerance. Spec within HTG Rent Protocol.
    Submersion Kinetics: RA 667.66 LA 667.88 RL 889.99 LL 890.74
    Forearm Prosthetic Munitions: USWR / FPA 10mm BioMech Fem/Mal Repeater 21+1 Ramapant - LC
    RJX REGEN: 7X Normal Rate over base metabolism. Muted effects resultion from all sedatives. Burns rate at 1.5X. Cell mutagenics over thys physics. Fascia damage unknown.
    Answer your question?
  15. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You have to realize, every cute animal on earth, at one time, was or will be ****ing
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    brought to you by north central positronics
  17. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    To be truthfull, not really.;)
  18. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    On July 15th 1984, RJ started learning at a geometric rate... on January 1st 2007 he became self aware..... they tried to pull the plug
  19. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    that you have too much free time and should get an additional job... ? lol
  20. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    My head and my free time = ART
    ...and yes I make damn good money off of art
