Ko Fords guys HELP!!!!!!!
Discussion in 'The Garage' started by justhorsinaround, Nov 25, 2003.
  1. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    My brother-in-law's Ranger (1992 4 cylinder 2 wheel drive) is overheating. We replaced the water pump (cuz it was leakin), the radiator (cuz it sprang a leak after we replaced the water pump) and the thermostat. The upper radiator is pretty much rock solid when the truck is fixin to overheat and the overflow tank is full.
    What gives?? I am completely at a loss and am probably overlookin somethin simple. Could one of y'all tell me what bonehead move I'm makin or what not? Thanks in advance.
    Allan
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    sounds like the therostat might be bad.people used to check them by putting them in a pan and boiling water to see if it opened. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    replace the thermostat, when you take the old one out, fill the block with coolant, that will help to eliminate any major air pockets..
  4. boggerless
    May 26, 2003
    22,728
    96
    WHAT, CONFEDNECK responding to a ford post??? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif just kidding /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. Confedneck
    Nov 1, 2002
    5,236
    lmao but of course, i do work on them every day.. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  6. justhorsinaround
    Sep 16, 2003
    6,798
    It has a 4 hour old thermostat in it already and no joy. It's like the water just can't get through the motor. The water pump is doin it's job I'm thinkin cuz like I said the hose is hard as a rock. Oh yea the heater doesn't blow hot air at all. Thanks again in advance.
    Allan
  7. Confedneck
    Nov 1, 2002
    5,236
    sounds like its air locked, pull the heater hose off the motor and fill it, fill the heater core, fill the block behind the t-stat and try again.
  8. boggerless
    May 26, 2003
    22,728
    96
    CONFEDNECK you think he could run it half capped(i.e. radiater cap somewhat open,till it bleeds itself)? let the air go somewhere. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Buy a thermostat with a check valve or drill a tiny hole in yours so it can't airlock. Next time don't buy a cheap thermostat. /forums/images/graemlins/rotfl.gif
  10. Confedneck
    Nov 1, 2002
    5,236
    he could let the truck run and get up to operating temps and try bleeding the air out by cracking the cap carefully and refilling as the air comes out..
  11. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i think you nailed got a up date for us
  12. boggerless
    May 26, 2003
    22,728
    96
    that's what i thought.i've had to bleed power steering on a mack and that was a beeeaatch.maybe the same thing. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
